Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
what will it run???
Old Jul 21, 2005 | 10:58 PM
mickman's Avatar
Car: 1991 Z28
Engine: 5.7L LT1
Transmission: 4L60
what will it run???
I'm getting some more mods for my camaro over the off season and was wondering what you guys think it'll be capable of? On top of my mods in my sig I'll be getting: SLP 1 3/4 coated shorties and Y pipe, cat removal for straight pipe, 3 inch cat back with loudmouth resonator with one 3 inch tail, lca relocaters, adjustable torque arm, BFG's and a 2500 stall! This baby should move pretty good after this, talk to me!
Old Jul 22, 2005 | 10:20 AM
mickman's Avatar
Car: 1991 Z28
Engine: 5.7L LT1
Transmission: 4L60
Anyone?
Old Jul 22, 2005 | 10:40 AM
mean57's Avatar
Car: 87 gta
whats it run now?
Old Jul 22, 2005 | 01:43 PM
mickman's Avatar
Car: 1991 Z28
Engine: 5.7L LT1
Transmission: 4L60
Never had it at a track and I don't have the funds right now to do so. I have no traction at all and a run at the track would be useless without BFG's. Until then I'm not going and setting myself up for dissapointment for no reason. When I get these mods done over the off season then I'll go in the spring and see what's up. but would still like guestimates!
Old Jul 22, 2005 | 07:17 PM
mean57's Avatar
Car: 87 gta
well judging by mods in sig you have added weight and about twenty hp. with the gear you should get a high 13 to very low 14
second pass. with the good exhaust and convertor you can probably take a .5 off of that. again this is just a guess
Old Jul 22, 2005 | 08:07 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Mid to high 13's. The LT1 will pull pretty hard. Who knows with sticky tires, low 13's Good Luck
Old Jul 22, 2005 | 10:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah with traction, you should be near low 13's. your probly pushing atleast 320hp on crank, and that stall will help your launch. i'm estimated 275hp crank and getting 13.8's with 2.77 gears. you should be deep 13's at 103mph or more
Old Jul 22, 2005 | 11:54 PM
mickman's Avatar
Car: 1991 Z28
Engine: 5.7L LT1
Transmission: 4L60
Thanks guys! I'm hoping for deep 13's. I saw a 93 LT1 powered camaro (wich mine is also) on the internet called the grapes of wrath (since it was purple). The goal of the project was to break into the 12's on a stock engine. Although this was never realized the car ran a 13.1. and if my memory serves me correctly the only mods that would differ from my proposed mods was a 2800 stall instead of 2500 and eibach springs. Keeping in mind also that my car weighs 200-300 pounds less than that car. I'm not saying my car will hit 12's, that won't happen I'm sure but I think a low 13 is do-able. My sub frame only weighs 26lbs! Thats why I went with spohn. The wonder bar weighs virtually nothing but the LCA's seem pretty heavy! Thanks boys!!!
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
