which wheels for autocross
Car: 91 z28
Engine: 350 tpi
which brands makes wheels for autocross? i dont want to spend more than $450 for each wheel and they should be strong wheels cause its going to be a daily driver. so what brand do you recommand?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
CCW makes good wheels. a few on this board have them i have seen.
do some searches for CCW wheels. not sure on the price of them but they are nice
http://www.ccwheel.com/files/home.php
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
which auto-cross class? the class you are in, may have a limitation to wheel size.
Car: 1990 Camaro RS
The thing is, certain classes have limitations on wheel size. If you are just starting out, I would take your car as is, figure out with the tech inspectors, what class your car is in, then check the rules to see what the wheel rule is. Besides, when you are just starting out, going in street trim, will help you learn much more, much faster. Racing tires can sometimes cover up mistakes that you would notice on street tires. I would suggest trying it out, and getting some seat time, before you start buying parts specificly for auto-x.
Car: 92 Camaro RS
Transmission: T5 manual
Originally posted by MrDude_1
i agree with dewey, but to answer your question, 17x10.5 CCWs..... all 4 corners... with some super sticky rubber..
Car: 1990 Camaro RS
I know that at least one member here has 18x11 CCW's on all 4 corners...
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Car: Z/28
Engine: 355
Transmission: Turbo 400
Since your new to autocrossing, Why don't you save some money by purchasing a set of 16x8 Firebird WS6 rims. they will be tons cheaper than CCW's . Then purchase some 255/50-16 Kumho 710's for them. Its a great combination to start with and will last along time and be very fast. The big CCW's are only needed when you are to the point "competitively" that you are ready to take on National events.
Car: 92 Camaro RS
Originally posted by camaro86
what kind of wheels do you have Axoid ? how wide are they?
Next year I moving up to Street Mod and once my new engine is done, I thinking of putting 18x10.5 - 18x11s on the front and 17x11s on the rear.
punkmaster98
Sep 8, 2015 09:45 PM
