Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
what will i run
Old Aug 19, 2005 | 02:49 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
what will i run
350 sbc
HSR
xr276 112 lsa cam
dart pro 1 aluminum 215cc runners 62cc chambers 2.05 intake 1.6 exhaust valves.
edelbrock headers, catback exhaust
3.42 gears
2400 stall
built tranny with shift kit and clutches
thanks ^_^
Old Aug 19, 2005 | 06:21 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If the 262 HP numbers are correct maybe mid 13's depending on the weight of your car and how well you hook up. With a light car and a good hook up maybe low 13's.
Old Aug 21, 2005 | 01:12 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ignore the 262hp..
thats what i have now before cam and heads..
and i run 13.8 with that 262 hp now.
so basically im adding the cam and heads
Old Aug 21, 2005 | 01:51 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Seems like the heads are bit big for the setup....
Old Aug 21, 2005 | 01:56 AM
JesasaurusRex's Avatar
id have to agree trav, i wouldnt go bigger than 200cc ports with a 350, thats just me.
Old Aug 21, 2005 | 02:00 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
got some 200cc's for me then?
Old Aug 21, 2005 | 02:03 AM
no, im just sayin, but work with what u got i guess
Old Aug 21, 2005 | 02:05 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
how about canfields for 800 bux.. 197cc runners 62cc cnc'd chambers?
2.08 intake 1.6 exhaust?
Old Aug 21, 2005 | 02:08 AM
sounds better to me, i like canfields better anyways.
Old Aug 21, 2005 | 02:10 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
What RPM range are you planning on making power in? You only have a 2400 stall and 3.42 gears. Make sure all your parts have the potential to work well together.
Trevor
Old Aug 21, 2005 | 07:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i would like to take it to 6 or 6.5k
i guess 215's would be good for real high revving eh?
or a supercharger
Old Aug 21, 2005 | 08:16 PM
the canfields will be more than sufficient up to that rpm
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
