getting close. need ideas
Car: 87 gta
ok. so now i'm at the time in my sig. and i wan't a 12 99
before i go for any tuning. do you think a good stall convertor and aluminum drive shaft will get me there? here is a list of my mods.
slp cold air, bbk twin 52tb, ported and siamesed plenum, as&m semi siamesed runners, tpis bigmouth manifold,
afpr@52psi, walbro in tank pump, stock injectors, heddman long tubes, true duals with h-pipe, electric waterpump, a/c smog delete, p/s delete, accell 300+ ignition, msd billit dizzy
& wires. ssm weld in sfc and liftbars.
Car: 87 gta
i wan't to say the converter in it is from a vette but i'm not sure
it was explained to me only as a stock stall when i got it.
it is a 12 incher. what do vettes hit at? i hit around 2k of idle
but brake torqeing it only holds to like 1600 rpm before the tires wan't to break.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah i think vette stalls are 2000 rpms
sounds bout that from a 1600 brake hold
anyway , yeah a converter could help you hit 12.9x's lol
i cant believe how quick ur car is with those mods. makes me hopeful when i get HSR and a tune next summer
Car: 87 gta
yeah i thought about changing intake design once then someone
let rip with tpi l98's can't run 12's on stock heads cam and bottem end. well you can see my results
Car: 89 Iroc-z
Transmission: TH400
mph is definately good with aftermarket TPI. with slicks and absolutely perfect launch i can see a high 12. aftermarket TPI with 1.6 rockers and a good tune will see 103-104mph or so. thats good for 12.9's for sure
Re: getting close. need ideas
What I don't see that can help is skinnies, disconnected or loosened front sway bar, roller rocker arms, underdrive pullies, disconnected alternator, tires (?), anything to lighten the front end of the car a bit, try an exhaust cutout, ice the intake...and a throttle body air foil, lol...
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
spend some money on a tranny
3500 stall, tranny brake, reverse manual valve body and shifter of your choice. that should bring your times down. and makes the car alot more fun to drive
Car: 87 gta
sorry for not listing but most ask for engine mods.
trans is a full race 700r4 built buy tsi racing transmissions.
i do run skinnys and slicks current 60's are 1.82-1.84 9bolt rear
with girdle cover runnin 3.27 gears crossing line at 4700rpm.
chassi is ssm sfc,cross bar and weld in liftbars. spohn trackbar, lca's and no swaybars.
and i forgot the crank pulley
