Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Post Pics Of Your Fuel Cell!
Old Jan 24, 2006 | 05:57 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I am thinking of putting a fuel cell in my car. Can some people post some pics of ones you have instaled so i can get some ideas.
thx
Old Jan 25, 2006 | 01:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
More of a "Racing" than "Carb" topic.
Old Jan 25, 2006 | 02:38 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well i geaused that since most people have droped the tank to take out the fuel pump when they put a carb on that some would put in a fuel cell instead of putting the stock tank back in.
srry for placement
Old Jan 25, 2006 | 11:02 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Why do you want a cell? The extra cost? Safety? B/c its shinny?
Old Jan 25, 2006 | 07:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
4 gallon cell is all I need.
Old Jan 25, 2006 | 10:14 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Thx for pics, but i am acturaly looking for some pics of a rear mounted cell. this is gona be a street car. Well kinda
thx
Old Jan 26, 2006 | 02:41 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Mine is a street car??
Old Jan 26, 2006 | 04:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sump the factory tank and that should be enough for a "Street" car. I have a -8an line coming off mine.
Old Jan 26, 2006 | 04:53 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well the the reason i want a fuel cell is because when i took mine out i bent the fuel neck up prety badly because i was in a hurry. So i want to put a fuel cell in it so if i have to ever take it out again it will be much easier.
Old Jan 26, 2006 | 10:47 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
Well I don't have any pics at the moment, but my fuel cell is in the rear in the lower trunk area. I cut out a small hole so that the fuel cell fitting would come out under the car, and my braided lines 90 around and the fuel pump is bolted to the back side of the trunk under the car. The little plastic door still closes over so that you can't see the fuel cell
Old Jan 26, 2006 | 11:02 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
what size cell?
Old Jan 27, 2006 | 04:32 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
RCI 4 gallon.
Old Jan 28, 2006 | 08:54 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Save yourself the hundred of dollare to convert car to fit a 12-16 gallon fuel cell and buy a brand new steel oem tank and sump for the best of both worlds that easily bolt into and come out of the car. If you bent it, you were in a hurry and did'nt take the right steps. myself and many other on this board have dropped factory tanks with no problems, I can promise the extra 1-2 minutes of being careful is going to offset the hours taken to intall a cell then make a steel rear firewall to seal that rear off from pass compartment. Also, plan on removing the carpet back there as well cuz once the gas drips and dribbles when your try to fill it, it will stink forever but it's a "street" car so you should'nt be needing to fill it very often right?
If you switch to an externally mounted fuel pump, why would you ever have to drop the tank if you sumped a factory unit? If this were a 2 day a week toy (sat and sun) and you had time to waste and money to spend the cell might be a cool idea, but they are not practical for a standard duty street car and 4-6day a week driving....just like a roll cage, cool, but I hate dealing with it after a while.
Old Jan 28, 2006 | 05:44 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Only reason I put in a Fuel cell is because I only race my car, and never knew how much fuel I had in it when racing. If its a street car, like IHI said, stick with a factory type fuel tank.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
colton_carlson
Mar 8, 2019 12:21 PM
project89
Sep 24, 2015 06:38 AM
Linson
Aug 21, 2015 02:12 PM
