Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
this spring
Old Feb 23, 2006 | 10:21 PM
hotshotcamaro's Avatar
Car: 89 camaro RS
this spring
looks like this spring i will b putting a new engine in my camaro, 350 bored .060
not sure on compression i will have to figure that out
stock heads
stock 700r4 (scarry)
stock 2.73 open rearend (scarry)
comp cams xe 274 cam and lifter set .487/.490
holley 750
edlebrock rpm performer intake
any clue if this can get me into low 14s until i can afford some decent heads
Old Feb 23, 2006 | 11:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
will that cam even work on stock heads without binding up? that cam won't be happy without a stall and bigger gears just so you know. it'll make for a really poor combination IMHO
Old Feb 23, 2006 | 11:15 PM
Car: 89 camaro RS
yeah i'm well aware it is a bad setup hoping to slowly improve it as i go along, i will have to double check my clearence on my heads
Old Feb 24, 2006 | 01:09 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Get decent tires, a converter and gears before putting that cam in a very mild, stock combination. You'll be much happier.
Old Feb 24, 2006 | 05:14 PM
Car: 89 camaro RS
i'm definatly gonna do tires and converter i decided, good chance i'll do heads b4 i throw it in too i decided
Old Feb 24, 2006 | 05:20 PM
xpndbl3's Avatar
Car: 1984 Z28
i'd do the tires, gearing, and converter/shift kit before you built up the motor. then move on to the motor.
Old Feb 24, 2006 | 05:26 PM
Car: 89 camaro RS
i think i'm just gonna drive that rearend until it blows up, and then throw a decent one in there, i don't drag race, its just a daily driver
Old Feb 25, 2006 | 11:03 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
If you dont race it then why not leave it stock. No use in making it fast if all you do is drive it back and forth to work
Old Feb 26, 2006 | 02:24 AM
Car: 89 camaro RS
no offense i see your opinion, but if like being louder and faster than the guy next to me at teh street light, gas milage makes no differnce to me, when the next bum in a civic races (although it was close b4) it will be nothing to run them down, i don't care about a 10 sec. timeslip cause i know it won;t happen
Old Apr 4, 2010 | 02:19 AM
Car: 89 camaro RS
Re: this spring
although this is kinda weird it is interesting to look back at what i wrote and wanted to do back when i was a teenagerm although prob. not smart
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
