GMHTP Budget Stock Motor Shootout
GM High-Tech Performance magazine is looking for good looking, stock motor Third and Fourth Gen Fbodies for a shootout in Englishtown, NJ's Raceway Park. This closed track event will take place Tuesday, August 1st at Old Bridge, NJ by invitation only. Those invited will be allowed as many passes as time allows while the GMHTP staff snaps photos for use in an upcoming article in the magazine. All cars must comply with Raceway Park's 95db noise restrictions and NHRA safety rules.
Stock longblocks including the cam, heads, internals, and block must all be utilized, however, all bolt-ons (including rocker arms) are acceptible as well as forced induction. Intake manifolds must be of stock style, meaning no carb-style or multiple throttle bodies. Racing transmissions such as TH350s, TH400s, Powerglide, or clutchless manuals are prohibited. Stock or built 4L60E, 700R4, T-56 or T-5 are acceptible so long as they were available from the factory in that model year. Any rear end (10 bolt, 12 bolt, 9-inch, Dana, 8.8 hybrid, etc) is acceptable as is any tire size or compound, so as not to require tubs or minitubs. Stock style suspension must also be utilized, so no ladder bars or 4-links. We would like to keep the entrants fairly streetable and stock appearing, meaning no completely stripped down racecars. To apply email an overall, engine, and interior .jpg to scott.parker@primedia.com along with timeslips, dyno numbers, estimate of total money spent, a list with your build up and NHRA safety equipment, home, work and cell phone numbers. The deadline for applications is June 4, and all invitees will be notified no later than June 18.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I'd def be interested in going. I have pretty much every bolton, no power adder,stock heads and cam(check sig) I've ran a best of 13.21@104.63 Three years ago and have been looking to get some new times. Let me know what you think!!
Car: 89 Formula 350
Originally Posted by xpndbl3
how would a shootout between 3rd and 4th gens be even remotely fair? only a difference of 85 hp or so between a TPI and a LS1 motor.
1 Post
Car: 89 RS
Transmission: TH350
there's no way a full bolt on TTA would even compare with a full bolt on LS1, there are some running low 10s on stock cam and heads.
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
Unfortunatly TTA's dont fit the above discription so looks like thirdgens will get crushed
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Steve
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Originally Posted by Scott@GMHTP
Stock longblocks including the cam, heads, internals, and block must all be utilized...
Most of my setup came from the factory, but not in a production car. Would the HO 350 Camaro conversion kit be "legal" in this "shootout"? If not, why not?
Basically, I'm not seeing it.
LOL, we can always beat up on the 4th gens with LT1s.
No, I believe you read it correctly. Back when I had my 355 in my Formula, I had T/F heads, ZZ-9 cam etc., and it would walk all over a stock, supercharged LT-1. Now, if this were a bolt-on, third gen only affair, then it would be interesting. A supercharged third gen would likely get beat by a stock LS1.
TTA850: if you are interested in entering please submit an application. Based on the rules I specified for the shootout, your car would technically check out.
five7kid: as stated in the rules, the engine must be completely stock as it came from the factory. Motor conversions are okay so long as that motor was available in that car during that model year, so for example a 305 TPI could convert to a stock 350. Please keep in mind that if the rules were different, you would be competing against cars with LS1, LS2, LS6, LS7 and C5R swaps (all of which came from the factory as well). And yes ported heads are not allowed, as are forged pistons.
Scott, I am a fan of GMHTP, and a subscriber as well, but I dont really see the point of this. We all already know what will happen. Why would anyone with a thirdgen sign up just to get wasted by a bunch of 4th gens? Where is the incentive for anyone with a thirdgen and what are you guys trying to prove? This will certainly not be educational, or even entertaining in my opinion. My car would not fit in the rules in any way, but even if it did I would not want to be pitted against an LSX motor'd car, there is just no comparison. Running an LSX car at the strip for fun is one thing, participating in an event that is specifically to pit LS1/LT1/L98 against one another is of little value in my opinion.
you can't port the heads? whatever your smokin', send some down my way!!! there is no way you can put a stock long block ls1 with boost next to a stock l98 with boost and get anything remotely close to a fair match. the crap hyper pistons put into the stock gen I smallblocks simply won't hold the pressure like an lsx motor will.
this is simply not a good way to prove that stock for stock the lsx motors are superior.
I have a better idea, instead of trashing on thirdgens, how about a Thirdgen shootout. Maybe you could take a bunch of clean nicely built thirdgens and run them at the strip. You could interview each owner and do a short writeup on each car. The puropse of the article would be to prove that thirdgens can be a great bang for the buck.
Better yet, I would like to see a 305 vs 350 shootout. Round up all the quick 305 guys and duke it out with some of the 350 guys around here. The title could read "305 vs 350 The Results May Suprise You" I think a grudge match with all the wimpy 350 guys would be a blast! jk.
Just some suggestions.
Engine: LS1/LQ4
Car: 89 Formula 350
A stock heads, stock cam, stock internals -no power adder (full bolton)TPI thirdgen shootout would be cool too!!
Engine: LS1/LQ4
I suppose we're sounding like a bunch of sore losers. Or, redheaded stepchildren.
To be honest with you, Scott, I subscribed to GMHTP for a year, let it expire because there just wasn't much there that was much use to a guy with a 20-year old car (that is his "new" hotrod) running a carb. The groundrules tend to support that decision, if you know what I mean. (I especially don't understand how poweradders can be allowed with the other restrictions that are being imposed - which is less "stock": home ported factory heads [or stock replacement heads], or a supercharger?)
Okay, I'll quit now. Guess we'll let GTA matt represent us all.
I've seen arguements about what defines "bolt-on" as well. Most considered aftermarket heads a "bolt-on", but not an aftermarket cam. Go figure. . .
Originally Posted by TPI-Formula350-
(full bolton)
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
GTA matt, only about 25% of the people on this board believe your claims, I am not included in that 25%. I don't think anyone that reads GMHTP will believe them either. The 104mph trap speed is just laughable out of a stock head, stock cam, stock intake L98. It would be interesting to see some dyno numbers for that car. Besides even if you can run those numbers your car is one of one in the world and would not be a typical representation of thirdgens. And back to topic, even though your car may run 12.9 which would be stellar for an L98, you would still get raped by an LS1 car with exhaust and a lid, as would mine I might add.
1 Post
Car: 89 RS
Transmission: TH350
My motor is stock. Whats up with that? Just let me get some gears and a 150 shot and the title is mine.
Anyways, good luck with a turn out on that deal. Let me know when you guys are in Texas again for some sort of fair shootout. I'l go to that one.
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
GTA matt, only about 25% of the people on this board believe your claims, I am not included in that 25%. I don't think anyone that reads GMHTP will believe them either. The 104mph trap speed is just laughable out of a stock head, stock cam, stock intake L98. .
Also, as 1MeanZ has stated above, an all third gen shootout would be great. I just happen to be one of the people that has had the privelege to attend a GMHTP shootout, and have their car in the mag. I was in an old High Tech Performance issue (before GMHTP). It was the May 1997 issue, and the article was called World War III. It was a 350 Camaro, that ran in the 13.00 range, a supercharged 350 camaro that ran mid to high 11s, and me, with my little 305. I only ran low 14s N/A, and 13.87@105, with a little shot of nitrous. Unfortunately, my fuel pump went south, on that very day, and pretty much stopped me from any ET improvements. (oh well). But back to the point, we had three similar cars, all with different mods, just to see how well they ran, and compared the various levels of mods, and their effectiveness. The third, and fourth gen event in question, is like pairing up two completley different animals, just to have a bloodbath,
![in my opinion](https://www.thirdgen.org/forums/images/smilies/stupid2.gif)
Car: 89 Formula 350
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I'm with 1MeanZ you post that your in the "12's with everything stock". Then I read your sig and your not stock,but your boltons wouldn't would not add upto 12's. Maybe we'll both get an invite to this shootout,i'd like to see what we both ET at after going through a tech to make sure we're as stock as claimed.
![your welcome](https://www.thirdgen.org/forums/images/smilies/welcome.gif)
Engine: TPI 5.7 L
Originally Posted by mw66nova
guys, please don't forget about track prep, elevation, and weather conditions. MIR is one of the fastest tracks on the east coast. i don't doubt his claims.
1 Post
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
This will be an interesting read when it comes out in the magazine.
I'm curious to know how many 4th gens have signed on for the up-coming slaughter.
Engine: LS1/LQ4
Intake manifolds must be of stock style, meaning no carb-style or multiple throttle bodies. ... Stock or built 4L60E, 700R4, T-56 or T-5 are acceptible so long as they were available from the factory in that model year. Any rear end (10 bolt, 12 bolt, 9-inch, Dana, 8.8 hybrid, etc) is acceptable ...
But...
A NON-GM REAR END IS JUST FINE!!!!!!!!!!!!!!
Either this is an attempt to tilt the playing field, or the rules have been very poorly communicated.
I still don't know if the ZZ4 is unacceptable - my argument would be that it should be acceptable, since the "350 HO Camaro Conversion Kit" was a factory motor conversion - emissions-legal, even. Hmmm, wonder how much uncleaned 113's would hurt me. . .
Never mind, I still have a TH700R-4. . .
![go crazy](https://www.thirdgen.org/forums/images/smilies/go crazy.gif)
yeah these rules are very poorly put together and sound like they were put together buy an ls1 owner, someone who probably never owned a thirdgen or if he did, it was 1988 or newer.
82-84 cars only got the carb or crossfire injection.
85-88, the lg4 was still available, so those guys gotta convert to TPI?
88+ was all tbi or tpi stuff, and the tbi stuff SUCKED.
so basically you guys are wanting to see the fuel injected thirdgen guys come out with a power adder, but other wise completely stock? this is ridiculous.
of course, i'm counted out completely. my heads are from a 1991 corvette and have been properly cleaned up. my cam is late 1960's technology, with it's solid lifters...but even with only 5.1L, i'd still take on any ls1 without nitrous or blowers with factory displacement.
Car: 89 Formula 350
Originally Posted by 89gta383
Don't hate on his combo because he did something you can't. Try to get there also by crossing your T's and dotting your I's instead of crying about what isn't 'stock' about his combo. Wasted energy on your part.![your welcome](https://www.thirdgen.org/forums/images/smilies/welcome.gif)
I'm not hatin because he did something I can't, I am hatin becase he did something that no one else can do, that ranks his claims as unfeasable in my book. So what, someone with a L98 trapped 102 with stock stuff, he is trapping 104! 102 is plausible but 104 is just silly, you have to draw the line somewhere guys. People can dispute me all they want my opinion will not change about his times, or his car. Also I will state again, GTA matts car even as fast as he claims it is will still get raped by an LS1 M6 car with a few bolt ons. So what if his car runs 12s, it will still get smoked so what is all this trying to prove?
Back to topic..
So Scott what are you going to do with the whopping 2 Thridgen entrants? do you have any reply to the comments listed above? I think we would all appreciate some more feed back from you on this topic.
Thats pretty funny because i'm already there. You can see my times and dyno sheets in some of my old post, alot of the guys on the boards know what my car runs. Anyway I hope to get there so we can see how everyones does, even if the LS1 cars smoke us all. Sure it would be a good time...
Engine: TPI 5.7 L
Honestly, it's just nice to get the invite. GMHTP is solely about Late model GM performance vehicles and EFI only. They had a LT1 vs. LS1 shootout a couple years back and several of the cars were in the 13's. A couple L98's running low 13's maybe high 12's would be nice to see. Some bolt-on TTA's would definitely make a third gen statement.
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
1 Post
Car: 89 RS
Transmission: TH350
TTA850: Please keep in mind that if the rules were different, you would be competing against cars with LS1, LS2, LS6, LS7 and C5R swaps (all of which came from the factory as well).
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
#42
Car: 2013 C63C
Engine: M156 (P31)
Steve
#43
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I think mines a perfect canidate
The only thing that may not be ok is my stall converter.
#44
you people b1tch too much, if you're not afriad of breaking it you could get NASTY on a stock L98 long block using race gas. albeit it's a carb, single turbo 305 dyno results
this is a LG4 which means crap cam, bone stock long block. The dyno sheet shows almost 300 to the wheels, that's LS1 territory and it's not even a 350 or equipped with the "good" cam. With a good TPI setup and engine management, even a stock L98 with an aftermarket intake and boost would be quite nasty on a race gas tune. This is an oppertunity, someone's gotta be the under dog
It's a good time for people to step up and show what these cars can do.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
#45
1 Post
![blah blah](https://www.thirdgen.org/forums/images/smilies/blahblah.gif)
Stock L98 + boost = rebuild
Been there done that (rans 12's briefly)
This whole thing is BS until Scott@GMHTP can fully explain how it works, who's racing who, etc etc etc,
#48
They should have thirdgen auto/thirdgen standard/4th gen auto/4th gen standard classes.
Comparing an auto L98 to a 6 speed ls1 is ludacris. I'm not whining their cars are faster, but they do have 20 years of technology and have the availible 6 speed, and they cost about 10x as much as a typical 3rd gen.
#49
Car: 2013 C63C
Engine: M156 (P31)
