Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
trap speed
Old Jul 4, 2006 | 05:35 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
trap speed
what kind of time does the average car run with a 92-93mph trap?
Old Jul 4, 2006 | 05:52 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
High 14's, low 15's.
Old Jul 4, 2006 | 06:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yep i seen alot of high 14's with a 93mph trap speed.
lots of wrx's do mid 14s (14.4-14.6) at around 92-94mph since awd gets good 60 foots. so with slicks or drag radials and good converter/or stick shift, i can see a thirdgen going mid 14s with 93mph traps
Old Jul 4, 2006 | 07:27 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Average for a decently setup and matched car is MPH * ET = 1350
1350 / 92 = 14.67
1350 / 93 = 14.51
Old Jul 5, 2006 | 12:35 PM
rhamm1320's Avatar
Mid 14 as mentioned above. This is only a estimate that does not factor in traction, chassis setup and aerodynamics. It is a good starting point though.
Free program if you want to play around with the numbers.
http://www.virtualengine2000.com/Calculator2006.htm
Old Jul 5, 2006 | 02:14 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
1350 / 92 = 14.67
1350 / 93 = 14.51
hmmm...12.50*106.8=1335...what gives? based on the mph, it says my car oughtta be running 12.64, and based on ET it says i oughtta be trapping 108mph...does this mean it's got more in her on the top end or something? i know the car needs a bit more gear...
Old Jul 5, 2006 | 02:33 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
That's more a rule of thumb than an exact product. Here are some examples of my #s.
Best pass 2006: 11.979@113.41 = 1359
Best pass 2005: 11.999@113.91 = 1367
Best pass old combo = 14.69 @ 92.00 = 1351
Looking at my log book from this year:
12.19@110.71 = 1349
12.11@111.85 = 1354
12.09@113.30 = 1370
Yoru car 60 foots a little better than others running the same ET and as a result your # is lower. Stock and Super Stock cars will have much lower #s while guys running while traction limited (ie on street tires) will have much higher #s. Ideally you'd want to have the same product all of the time.
Old Jul 5, 2006 | 10:29 PM
3rdGenBlackBird's Avatar
Here's the way I heard it- same thing.
PHFBA -> 1320 Method
Old Jul 6, 2006 | 11:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
1320 - interesting concept.
Using best runs, the Camaro is 1378, the '57 1340. However, my last round in the last race I ran is a 1260! (I backed off in the traps because the other guy wasn't catching me.)
Old Jul 6, 2006 | 12:07 PM
327???'s Avatar
thanks, i ran a 14.8 at that speed with some carb issues(not at wot and no back barrels, its fixed now) according to this i really need to get those 3.73's sitting in my garrage in the car.
Elephantismo
Feb 13, 2019 12:51 AM
Veaceonee
Sep 29, 2016 08:15 PM
RedLeader289
Sep 23, 2015 06:50 AM
abray1
Sep 14, 2015 08:18 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
