Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
new build
Old Feb 13, 2007 | 05:43 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
new build
87 camaro gutted battery relocated ,90/10 struts,4" harwood cowl,b@m pro stick, 295/50/15 radial ta's summit seats, weld pro stars
355ci
dart platinum iron eagles 215cc 64cc combustion chambers 2.05 1.60 valves
510/488 lift cam 114 lsa 234/244 .50 duration
holley street dominator intake
holley 650 dp
headman longtubes 1 5/8
1.5 roller rockers
flat top speed pro pistons
th 400 shift kit 3500 stall
3.73 gears
any ideas on times or h/p
thanks
Old Feb 13, 2007 | 07:02 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
12.30s maby faster. How much comp did you zero deck the pistons? Why the 114 lsa are you fuel inj ? Good luck!
Old Feb 13, 2007 | 07:13 PM
Car: 1987 iroc z
didnt check deck height but compression should be around 9.5 the cam has a 114 beacuse i had it on a fuel injected car. im thinking about geting a new one befor throwing it together.
Old Feb 13, 2007 | 11:00 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, definitely get rid of that crappy performer rpm camshaft.
Old Feb 14, 2007 | 12:47 AM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
I ran those exact head on a 355 sbc with at .525 .525 cam on a 110 and i ran 12.1's i think with a better cam you could have alot more potential. I was fuel injected with a stealthram.
Old Mar 4, 2007 | 02:47 PM
Car: 1987 iroc z
do you think a cam with a 108 lsa would be ok with power brakes.
Old Mar 4, 2007 | 02:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i run 106 with power brakes
Old Mar 4, 2007 | 04:32 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
the LSA is not what determines if you can run power brakes or not.. its the duration.. i barely had power brakes with a 110 LSA.. but my duration was 248* @.050".. now i run a 110LSA with 260*@.050" lift.. power brakes are not even an option, i have to run an electric vacuum pump to make things slow down..
Old Mar 4, 2007 | 11:00 PM
xpndbl3's Avatar
Car: 1984 Z28
i've run 250/260 duration cams on 106 lsa with a vacuum canister, so it's not always a set number
Old Mar 6, 2007 | 03:09 AM
83 Crossfire TA's Avatar
It’s up to the total overlap… for example, a lot of OEM truck cams have a 109LSA and they work fine with power brakes, plenty of vacuum, but they also have fairly small lobes in general so there isn’t much overlap no matter how you space them.
Old Mar 10, 2007 | 04:23 PM
Car: 1987 iroc z
im thinking about geting this cam http://store.summitracing.com/partde...4&autoview=sku
i was thinking about puting a 100 shot to it would it hold up and what times would i be looking at.
Old Mar 26, 2007 | 01:19 AM
Car: 1987 iroc z
Re: new build
ok i just got a new cam isky 507/507 lift 247/247 @ .50 108lsa vic jr intake 27/11.5/15 hoosier quick time pros. also would anybody know what rpm would be safe to shift at the sucky thing is i have stock rods and bolts.
Old Mar 26, 2007 | 05:29 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Re: new build
With a cam and head comgo that big you will have to shift some where around 7200 - 7500 rpm you are going to need a good converter and at least a 4.10 gear. stock rods as long as thay ar X rods or GM pink rods would be ok but stock rod bolts im not sure I would try and spin the motor up with them. I have always used ARP bolts in the stock roded motors and now I just order eagle sir rods or scat I beams.
Old Aug 15, 2007 | 09:18 PM
Car: 1987 iroc z
Re: new build
finally went to the track today sorta upset i definatly need new rearend gears.
first run bogged off the line and it went into second by itself at 5000rpm and second to third the same rpm i think i need to mess with the weights and springs in the tranny. went through the trap at 3800rpm.
60" 2.405
1/8 9.30
1/4 14.13
mph 101
second run bumped the timing up and took the vacuum hose off the tranny cause i thaught i could get some more rpm's out off it. it took off ok shifted into first at 5000rpm again and it held second all the way to the finish went through the trap at 6200rpm didnt even need to shift into third.
60"2.154
1/8 8.9
1/4 13.75
mph 104.65
i need to get some new gears i was hoping for 12's just for now to get it to shift at 6300rpm from first to second should i just change the weights in the govoner i want to race at the chevy show next weekend and want to get some more out of it.
1987 iroc camaro gutted, 4" harwood cowl lift off, lakewood 90/10 struts lakewood 50/50 shocks, battery relocated to rear, b@m pro stick shifter, weld pro stars 15x6 in front 15x8 in rear, hoosier quick time pro 26/10.5/15,
355ci
dart iron eagle 215cc platinum heads with 64 cc chambers with guide plates, isky 507/507 lift 247/247
.50 lift with 108 lsa, victor jr intake ,holley 650dp choke horn milled, 1.5 roller rockers, moroso tall valve covers, hyper flat top pistons with 4 valve relief, stock rods, eagle crank, 1 5/8 longtube headers with 2 1/2 pipe and dynomax race bullets, turbo 400 trans with b@m shift kit and unknown 3500 stall, all with a stock 10 bolt that will blow up the first time down the track LOL.
Old Aug 16, 2007 | 12:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: new build
what rear gear gets you to 104mph in 2nd???
Old Aug 16, 2007 | 02:52 PM
JesasaurusRex's Avatar
Re: new build
Um, it's both
Old Aug 16, 2007 | 04:16 PM
Car: 1987 iroc z
Re: new build
not sure on gears but must be pretty low. if i can get my trans to shift out of first at 6500rpm and lower my 60's down do you think i can get a low 13 dont have the money right now to get new gears. also is 104mph fast for a 13.7 what mph does it take to run a high 12.
Old Aug 16, 2007 | 05:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: new build
Originally Posted by JesasaurusRex
Um, it's both
actually it's valve overlap, # of ci, etc etc
time to pull the rear cover and change the fluid anyways, then find out what number is stamped on the ring gear to determine gear ratio. every .1 taken off the 60' is typically .2 taken off the ET. Also, my old 305 ran 13.0 at 103mph, so a 104 "should" be good for high 12s if your combo was matched, which it isn't with this salt flat gears.
Old Aug 16, 2007 | 05:46 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: new build
Why arent you manualy shifting it?
Old Aug 16, 2007 | 07:47 PM
Car: 1987 iroc z
Re: new build
even if i do manually shift it it still will go into second on its own it shifts at 5000rpm by itself and yes the cable is adusted right. but i just got done changing the weights in the govoner and now it shifts at 6600rpm. So the reason im not running any faster is beacuse of the gears not being able to get me a good 60'
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
