Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Just shaved off a few pounds on the front
Old Mar 7, 2007 | 03:41 AM
EvilCartman's Avatar
Car: '82 Z28
36 lbs taken off by switching to these Stock wheels were 41 lbs each, these are flickering 22.5 on my scale so I'll call it 23 each. Tires are 26x4.5x15 Moroso DS2 and the large fender gap is because the car is on the lift. Finally got some wheels to match the back pro stars Hope to hit the track on the 17th of this month, found out this weekend's track day has been called off.
Old Mar 7, 2007 | 07:36 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
looks awesome! maybe you'll see 11.3x's now
Old Mar 7, 2007 | 08:42 AM
Car: '82 Z28
I'm just hoping to get the car running right again let alone run a new best number Just upped the compression from about 9.8:1 to 10.5:1 and installed a windage tray last month. Also have a different carb coming so the Mighty Demon 850 will be going on the shelf.
Old Mar 7, 2007 | 10:31 AM
Car: 91 z28
what carb did you end up going with? that up in the CR will deffinately give you lots more power, windage tray will easy the stress some. i think going to anything from a demon or edlebrock should results in a few tenths,
Old Mar 7, 2007 | 02:36 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Looks good! I'm sure you will see a difference in ET too, its amazing what a rotational weight loss can do.
Old Mar 7, 2007 | 03:33 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks really sharp and having matching rims is always a plus
Old Mar 7, 2007 | 06:10 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
why don't you post a pic of the whole car?
Old Mar 7, 2007 | 10:13 PM
Car: '82 Z28
Ended up getting an older slightly used Mighty Demon 750 off ebay (still looks almost new), should be here Monday. Just can't get the 850 to run right no matter what so I'll save it for a BBC project.
Hard to get a pic of the whole car in my shop
Now just picture the new front wheels on instead of the stockers
Old Mar 7, 2007 | 11:03 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
15x4's or 15x 6's??
Car will look sweet with those weld's on the front!
Old Mar 7, 2007 | 11:36 PM
Car: '82 Z28
15x3.5 15x10 5.5 bs are in the back with Hoosier 28x9 slicks.
Old Mar 8, 2007 | 07:29 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Man Evil, tight car...Good luck at the trackk.....
Old Mar 8, 2007 | 09:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
I need some Prostars on the front of my car. I had Draglites all around and when I did my back half, I got a good deal on some 15" wide Prostars for the rear. I still have the draglites on the front.
I have some Aerospace drag brakes on the front. The hubs have a dual bolt pattern so if I can get a good deal on some front prostars, they can be in Ford or Chev bolt pattern. The Draglites are already a dual bolt pattern rim but Prostars are not.
Money no problem? I'd get some Bogart rims. Even lighter than the draglite and prostars.
Old Mar 9, 2007 | 12:04 AM
Car: '82 Z28
Those Bogart wheels are what a friend of mine uses, I think. He changed his front brakes out to shave off 40 lbs, cost him 2 grand though. The guy has done so many things to his car it's unreal and that's only the stuff he's telling me about hehe.
Old Mar 9, 2007 | 11:15 AM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
I just shaved a few pounds myself
Old Mar 9, 2007 | 01:01 PM
DIGGLER's Avatar
what kinda rack is that? i tried to fit a LT1 rack in mine but the steer shaft wouldnt work with it. (pa k-member)
Old Mar 9, 2007 | 10:27 PM
BT283's Avatar
its a flaming river pinto rack
Old Mar 9, 2007 | 11:15 PM
Car: '82 Z28
That's a lot of weight off the front
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
madsv1000
Aug 20, 2015 06:45 AM
