5.7" vs 6" rod 383 pros/cons?
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Just wondering what the advantages and disadvantages of a 383 with either a 5.7" or 6" rod were. i have 5.7" right now but am considering the 6"ers. Thanks
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: 5.7" vs 6" rod 383 pros/cons?
this is what i do know:
5.7" is better for lowend.. faster piston speeds increase friction and wear on cylinders.. better for cam clearance.. lighter rod but heavier piston
6.0" is more for upper rpm.. slower piston speed for less friction and ability to hit upper rpms easier.. but the wrist pin is in the ring lands and that could result in weaker pistons.. more clearancing for cam and heavier overall..
i could be wrong so please correct me..
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I've talked to local machine shops, read some articles from reher morris and on a dyno there is no advantage to either rod in the hp/tq...just is'nt happening. The biggest reason they push long rod is it does'nt side load the piston as bad using a 6" vs a 5.7" rod and you can also use a lighter piston since your moving the pin heigth up in the piston itself. Either way, if somebody tells you they made more power using a 6" rod over the 5.7, for sake of making yourself laugh as if they also stepped up to 1.6 rockers over 1.5 LOL!!
If your buying new rods anyways, go ahead and get the 6" for what little bit of advantage it will have with piston loading, but if you already have 5.7 stuff you can use, put the money for the 6" rods towards better use.
Car: 91 z28
well i have 5.7" i-beams and i want to upgrade to H-beams thats why i asked, will i have to go with different pistons as well? I've already upgraded from a cast steel crank to a 4340 callies compstar crank, and i had forged pistons, so i figured i'd trade in my scat i-beams for some h-beams to make the bottom end bulletproof. thanks guys
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I had a 383, I was using the short 400 rods. The engine pushed my car into the high 11's.
Using a longer rod moves the wrist pin higher into the piston (special pistons). With the short deck height of a SBC, the wrist pin can only go so far. Moving it into the oil control rings isn't too big of a problem as they'll use a support rail. Move it up too far and it gets into the compression rings.
Using 400 rods for a 383 means using factory stock style 350 pistons. Using 5.7" 350 rods means needing a stroker piston. In the early days of building 383's these were not available or very expensive. Now with the huge aftermarket supply, 6" rod pistons are available. Not sure on the cost for either stroker piston but as mentioned above, the engine won't make any more power from a longer rod. It's unlikely you'll see a performance difference unless it's an all out drag car operating above 6000+ rpm.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Everything I've heard says that in practical terms (HP, etc.), there's little-to-no difference between the 5.7" & the 6" rod. As IHI & Stephen have written, it'll affect your piston setup, but if you know that going in, there shouldn't be any problem.
Myself, I'm going to get the 6" rods for my 383 for two reasons: One, it might be a slightly more long-lasting combo with the slightly-lower side loading, and Two, I'm told that the 6" rods are a little quieter (mechanically) so the knock sensor won't have as much "ambient noise" to deal with. Is that a big issue? Probably not, but as long as I'm buying new rods anyway...
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I like the 6'' rod combo also but if you are running a power adder a 5.85 rod length will work better to keep the strength in the piston. Worked on a procharged 383 with the 6'' combo that loved to break ring lands.
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
V8Rumble: So youve found the 5.7 rod motors to have a slightly more audible knock then the 6" motors or is that just something that has been said in the past? Just curious.
Car: 91 z28
knock isnt a problem as i am carbed, i guess i will just go with 5.7" h-beams as i am not really wanting to buy new pistons. Thanks guys
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
my machinist said that a 6" rod motor will produce more torque than a 5.7, but for the street a 5.7 is better due to not interfering with the oil control ring.
LT1Formula
Oct 8, 2015 08:34 PM
