Drag front wheel backspacing?
What backspacing front wheels are you running? Seems like most come in 1.75 and 2.25” backspacing and it seems like the 1.75” ones would fit best on just about everything, but there are a lot of sets of 2.25” ones around so I was wondering…
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Drag front wheel backspacing?
1.75" MT ET drag's on 15x3.5" wheels here, gives it a little wider stance and helps the handling on the street a bit.
These are teh 15x4 drag lites...only one back spacing option...hope it kinda helps with the decision, i think i made a similar thread way back when. Think i opted for the x4s just cuz i thought it would see the street more than it does. Oh well, here ya go.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I run Weld Draglites on the front. The 3-1/2" rim only offers one backspacing of 1.75". The 4" rim only offers 2.25" backspacing.
With these narrow rims for your front wheels, you don't really have a choice in what backspacing you want until you get into a 7" wide rim. The same goes for the Prostar rims.
http://www.weldwheels.com/wheels/det...loy%20Polished
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i run the 15x4 with 28x7.50 M/T sportsman pro front tires and it works well for me.
Car: 1987 Camaro
Engine: 406
Axle/Gears: Moser 31 spline / 4.86
I have 15x4's with 1.75 backspacing. with 26x4.5x15 MT ET fronts
Car: 1984 Z28
15x8 with 4.5bs
15x10 with 5.5bs
15x10 with 5.5bs
Car: 87 IROC L98
Was 15 x 10 with 5.5bs
After the back half project, 15 x 15 with 5.5bs but there's enough room that I could do 6.5bs if I had the rims
I’m shooting for 15x10 with 6” BS, 9 with 5.5” or 8 with 5” bs, so they’re tucked in more like stock and not sticking out like most people’s drag rears…
Sounds like when it comes down to it either common front BS works but the lesser backspacing is probably more along the lines of what I want…
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
