Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
First time at the Strip - 89 camaro iroc
Old Jun 9, 2007 | 10:32 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So they had a test and tune night on my day off so i headed up their now that my car is running good.ended up doing 3 runs with a best time of 14.580.What does a car with my gears and motor run stock from the factory.89 camaro iroc 5.7 tpi700r4(auto) 2.77 gears 9 bolt posi, 21.5 lb injectors(ford racing) 3in flowmaster exaust ypipe w/ dual exit. stock manifold, no air filters. Everythign else is stock. Tire pressure 23 rear 35 front.Enjoy the picsI have videos but they arnt uploaded yet ill put up a link or the video itself later.
Old Jun 9, 2007 | 10:38 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: First time at the Strip - 89 camaro iroc
I have 2 buddies with 89 Irocs on ran a 14.7 stock with 2.77's,the other did a 14.2 stock, dual cat car with 3.27's
Old Jun 9, 2007 | 11:16 PM
Car: 89 Iroc
Engine: 5.7 TPI
thanks for the info. yea thats good to know that my car is running fater then stock would be. that gives me hope that i only have 95000 not 195000 lol darn 5 space odometers
Old Jun 10, 2007 | 11:34 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no reason to run street tires that low in the rear. Drag radials maybe, but just street tires should be around 30-ish. Keep trying to drop those 60', more gear would help as would a S10 converter.
Old Jun 10, 2007 | 12:10 PM
Car: 89 Iroc
Engine: 5.7 TPI
s10 Converter? Yea i didnt really mess with the tire pressure at all i just set them to 23psi. It gripped great some of the guys were running 20psi on street tires. Ill have to try soem different psi and see how that goes.
Here is the video if my 14.580 @ 94.18 MPH run
http://youtube.com/watch?v=RxhospZJsDM
Old Jun 10, 2007 | 01:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Nice times. Looks like you were really snoozing at the line.
Old Jun 10, 2007 | 05:22 PM
xpndbl3's Avatar
Car: 1984 Z28
S10 converter is a cheap way to get 1000 more stall rpm or so. It stalls around 2200-2400 compared to the stocker which is 1300 IIRC.
1998 S10 4.3L 2 wheel drive....get it at autozone, pep boys etc wakes up a stockish motor quite a bit.
Old Jun 10, 2007 | 08:06 PM
Car: 89 Iroc
Engine: 5.7 TPI
Yea, my r/t really sucked i progressivly went from .8-- to .4-- which is still crappy but it was fun and im deffinatly going back to run every chance i can. one dayll ill be good Thanks for the info on the converter. Im actually planning on gettin this one all preped for paint and gettin it pained here in the next 2 months and then ill be reselling it to get one with the t-top, atleast the 5.7 auto. and preferably with the 1le package.But then again i might end up keeping this one and just buying another one and have myself 2 thirdgens so when i was stalling at 2000 rpm at the line it was just a waist of energy because my stall is only 1300?thanks
BlueIroc-Z
Jun 9, 2019 03:22 AM
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Rustyweb7
Aug 9, 2015 03:05 AM
