Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
what it will run
Old Oct 16, 2007 | 08:31 PM
new camaro's Avatar
Car: 1992 camaro rs
Engine: Carderated 305
Transmission: turbo 700 r-4
Axle/Gears: n/a
what it will run
i have a 92' rs with a carberated 305 in it. it has edlebrock 650 cfm/intake manifold combo, turbo 700 r-4 tranny, summit headers and no a/c. what might it run if i get slicks on the 1/4 mile at 6000 ft. altitude.
Old Oct 16, 2007 | 09:12 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Re: what it will run
low 16-high 15
jeffcj's Avatar
That should get you into the 15s I think...
Old Oct 17, 2007 | 11:29 AM
new camaro's Avatar
Car: 1992 camaro rs
Axle/Gears: n/a
why does nobody like the turbo 700 r-4's is there somthing i am missing, and are the stock gears for the 92 rs
Old Oct 17, 2007 | 11:48 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
They are very difficult to build to hold any amount of power.
Old Oct 17, 2007 | 11:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Gears - check the data linked from the thirdgen.org homepage. Most likely you'll need to look at yours to get exactly what they are.
Who said anything about not liking the TH700?
About your combo: Edelbrock carb - no love lost with me on that piece. 650 is probably a bit large for a basically-stock LO3. Edelbrock manifold - which one? Summit headers - small tube wonders, okay for low RPM torque, not much for power, but probably aren't going to hurt your car. Sounds like you still have a stock cam and heads - both are EPA pacifiers.
At 6000' (assuming you mean Bandimere), I'd expect mid-16's out of it. Traction probably won't be a problem if you have stock gears. Unless you're running on Wednesday night "Take it to the Track" where all the front wheel drive cars screw up the pad. And they don't waste a lot of money on VHT on Wednesday night.
Old Oct 17, 2007 | 01:22 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Ya, with that combo and 6000 ft you'd be lucky to break a mid 16...
Old Oct 17, 2007 | 03:35 PM
new camaro's Avatar
Car: 1992 camaro rs
Axle/Gears: n/a
yeah, i will be at bandamire on high school drag nights and there are a lot of ricers. i need to get my carb re-jetted because the guy i bought it from drove here from sea level.
Old Oct 17, 2007 | 05:24 PM
five7kid's Avatar
They actually prep the track pretty well for the high school class because there are several true 11-sec race cars that run in that class.
We had a little traction trouble with the Camaro in the HS class, but managed to figure out a burn-out and staging process that eliminated it.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
