Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
idea on 60ft times
Old Oct 16, 2007 | 08:59 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
idea on 60ft times
im puting a jegs 3500-3800 stall in tomorrow. how low do u think i can get my 60 ft with my set up? my lca and penhard are boxed in to
Old Oct 16, 2007 | 10:09 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: idea on 60ft times
1.70ish or better.
Old Oct 17, 2007 | 11:50 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Originally Posted by F-BIRD'88
1.70ish or better.
and mid 12's too.
Old Oct 17, 2007 | 08:49 PM
intex1982's Avatar
i got it in.what a big help. whats the best way to take off with it?
Old Oct 18, 2007 | 12:19 PM
F-BIRD'88's Avatar
From an idle, or as close to an idle as yu can and still get clean throttle response. (some single plane manifolds)
Old Oct 18, 2007 | 05:51 PM
intex1982's Avatar
do i need a trans cooler and i dont drive it much
Old Oct 18, 2007 | 06:20 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
I've pulled 1.8 60's with stock suspension (except for Eibach Sportlines which probably don't help much and a panhard rod). My shocks are the original 100k mile junkers. I feel I should be able to possibly pull a 1.7 next year with more practice launching.
Old Oct 18, 2007 | 06:24 PM
intex1982's Avatar
whats ur stall and 1/4 time
Old Oct 18, 2007 | 06:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
on regular tires? or stickies? if you're on sticky tires 1.80's should be effortless, even 1.70's would be easy. I have 27x10.5 Hoosier QTP's and completely factory suspension minus the sway bars. On a decently prepped track I could do 1.56-1.58 60ft's all night. No effort whatsoever... just a light burnout, footbrake the car to like 1800RPM and take off with the nitrous on a WOT switch.
Old Oct 18, 2007 | 07:07 PM
Engine: 400
I have a T5 with 3.23s in the rear. I'm using drag radials. I've ran a 12.8 so far; and I'm pretty sure I'll go faster on the motor. No nitrous yet. I'll replace the rearend/transmission before nitrous.
Old Oct 18, 2007 | 09:41 PM
intex1982's Avatar
key there is t5 and 3.23. the 3.23 are not helping ur 60ft
Old Oct 18, 2007 | 10:52 PM
Engine: 400
Not to steal your thread, but yeah. I was wondering about going with a lower gear like a 4.11 or something. But I've noticed that right now, I cross the finish line pretty much at red line in 4th gear (5500). If I put in 4.11 or even 3.73's won't I be in 5th gear then?
And I'd never give up my T5. Well I'd give it up for a T56 or Tremec TKO
Old Oct 19, 2007 | 12:05 AM
EvilCartman's Avatar
Car: '82 Z28
I'd say yes if you're going to do any street driving. Even after a single pass in my car the temp goes up to around 160 ish if I remember right. That's with a 4,000 stall and cooler. On the street it only warms up a little bit.
Old Oct 19, 2007 | 10:39 AM
intex1982's Avatar
codename id say 3.73. with 4.10 and 26 in tires in the 1/4 im 5700rpm i think and trap 105
Old Oct 19, 2007 | 10:51 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
...I cross the finish line pretty much at red line in 4th gear (5500). If I put in 4.11 or even 3.73's won't I be in 5th gear then?
That depends on your engine's peak output, you may want to be pulling beyond 5500rpm. What's your heads/cam combo? What is the car's trapspeed like now?
Old Oct 19, 2007 | 11:53 AM
Engine: 400
I've run 12.8 at 108. I feel the motor has much more if I can get my 60' down. Here's the motor. It's a build out of Chevy High Performance. Run on 91 octane.
406ci with dished pistons
Vortec heads
1.5 roller rockers
air gap intake
Lunati 00010 cam (230/230 .480"/.480")
Holley 750 cfm DP
I have a 412ci no roller rockers and a 700 cfm Holley DP. I run open headers at the track (Hooker 2460 shorties). I'm running a 16 inch iroc rim with a nitto drag radial. I just shift at 5500 every time. That's what I should do right?
Their Dyno numbers.
RPM Torque HP
2,500 477 227
2,600 483 239
2,700 488 251
2,800 489 260
2,900 490 271
3,000 493 282
3,100 503 297
3,200 511 311
3,300 516 324
3,400 521 337
3,500 525 350
3,600 525 360
3,700 524 369
3,800 522 378
3,900 519 385
4,000 515 392
4,100 512 400
4,200 508 407
4,300 504 413
4,400 500 419
4,500 491 420
4,600 480 421
4,700 471 422
4,800 464 424
4,900 457 427
5,000 449 428
5,100 440 427
5,200 431 426
5,300 420 424
5,400 411 422
5,500 406 421
Old Oct 19, 2007 | 12:17 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
SO how you like the new converter?
It should have really woke the car up. I run a external cooler as well as the factory radiator cooler. Thats the best way I have found.
Are you going to get some track time? Let us know what it runs.
Old Oct 19, 2007 | 12:24 PM
atc3434's Avatar
Car: 1986 Camaro SC
Vortec heads
1.5 roller rockers
air gap intake
Holley 750 cfm DP
Their Dyno numbers.
RPM Torque HP
2,500 477 227
3,300 516 324
3,400 521 337
3,500 525 350
3,600 525 360
4,800 464 424
4,900 457 427
5,000 449 428
5,100 440 427
5,200 431 426
5,300 420 424
5,400 411 422
5,500 406 421
That motor would probably tolerate more carb, a 750 or 800, you've feeding a pretty good sized motor with quite a bit of duration on the cam (that was 230* @ .050 right?) I would be interested to have seen what a dyno pull to 6000rpm would have looked like. Maybe 5500rpm is about right. Experiement some at the track, make a few passes shifting at 6000rpm and see if the ET drops or climbs. Shifting at 5500rpm on a carbed/cammed 350 seems low, but I'm not sure about a 400. One thing I'd bet is that your carb is holding you back.
Old Oct 19, 2007 | 01:09 PM
Engine: 400
I was told by a lot of guys at the track to go no larger than a 750. They said this 700 would work well. Duration and lift are @ .050.
Old Oct 19, 2007 | 01:25 PM
atc3434's Avatar
Car: 1986 Camaro SC
Hmmm... I would think with those cubes, and that much duration on the cam, that you'd pull a fair amount of air. Most mild 350's run well with a 750 carb, I can't see a 400 with decent cam demanding less...
Then again Engine size (cid) x max. rpm/3456 =cfm
400ci x 6000rpm / 3456 = 694cfm
And thats at 100% VE, take that to 85% and the cfm is 589.9
Gotta take it with a grain of salt though, we all know 600cfm on a cammed 400 is undercarbed, signifigantly.
Last edited by atc3434; Oct 19, 2007 at 01:45 PM. Reason: Adding crazy formulas I'm not sure I believe, just to contridict myself
Old Oct 19, 2007 | 02:39 PM
intex1982's Avatar
i love it.i just put a cooler on 2 hrs ago.im going to the track tonight to see what car does. if it dont rain. and what psi should i run in my mickey thompsom et street radials? as a start point? it 25 psi now
Old Oct 19, 2007 | 02:47 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
start at 20psi. that's what i run and it works really well in most cases. i'm running a 275/60/15 on a 15x8 wheel. go down 1psi per run till you hook.
Old Oct 19, 2007 | 07:36 PM
327???'s Avatar
Looking forward to it! We have EXTREMELY similar combos and my 3500 stalled th350 will be in and driving by noon tomorrow and at the track on sunday.
Old Oct 19, 2007 | 11:07 PM
intex1982's Avatar
not to happy with the runs tonight. my best time of the night was 12.992
@ 103.9 mph on a 1.837 60ft. i got it to hook 3 times out of 8 the rest was 2.2xx 60fts time. i have seem to lose some power up top to. why? last week 105.xx mph this week 103.xx mph
Old Oct 20, 2007 | 01:22 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
How was you leaving the line? What RPM? Were you letting it flash, or holding the brake are a certain RPM?
What kind of air pressure were you using? Did you check the front tires. You would be suprised how much you can pick up with 40psi in the front tires. Better roll out.
Old Oct 20, 2007 | 01:31 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Also are you running LCA relocation brackets? They made a big difference on my car. I am also running the Hoosier QTP's. I dont know how they compare to your M/t ET Street Radials, but I love my Hoosiers.
Old Oct 20, 2007 | 01:50 PM
intex1982's Avatar
How was you leaving the line? What RPM? Were you letting it flash, or holding the brake are a certain RPM?holding breake to 1500 rpm and flashing
What kind of air pressure were you using?20psi Did you check the front tires. no
no
Old Oct 21, 2007 | 10:44 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I'll tell everybody again, throw all your math, throw all your hot rods and super chevies in the garbage when you start talking carb sizing...or go fast combos in general...throw out the engine and chasis dyno results too...the only way to know exactly how your stuff will respond is to change stuff on the track.
Our 383 in the s10 was at 105%VE on engine dyno, only pulled 697cfm so dyno dude said the 750hp we did pull with was perfect. i had'em throw a 950hp on and numerically we lost hp and it threw our tq curve for loop, on the track with the 750 it ran good, we finally put my 950 on it...and it ran great- .15 increase on a fat tune from my car...and the 750hp was tuned perfectly.
I've never really seen a car overcarbed out there...i was running this 950hp on my old 9.3:1 355 and it went faster in the 60', 18/mi, 1/4mi, and mph than the 600VS, 650DP, 750VS, 700DP, 750HP, 830DP....at this point after all i've seen, i have zeero faith in any formula, seen them busted tooo many times to have any faith at all in them...you will too if you hang around the track enough..same with magazine articles...they make good toilet reading/entertainment...and tha'ts about it...i look at those magazines like WWE wrestling, and believe them about as much too
Old Oct 22, 2007 | 06:51 AM
atc3434's Avatar
Car: 1986 Camaro SC
Exactly. Just try some different things. You said the car felt weak at the end of the track, that continues to make me think you're under-carbed. Like I said, a 750cfm carb will usually run pretty good on a mild 350, and your air demands are higher than that, so I would think 750cfm would be a starting point.
Old Oct 22, 2007 | 01:52 PM
intex1982's Avatar
i found my vavle lash was off alot (1/4 turn) on a few vavles never have rechecked it till yesterday. i knew going down the road car sounded rough. now it dont sound rough any more and really pulls hard in third gear now. and friday night it was poping at the end of the 1/4. so could that of been why it wasnt pulling hard up top? on the carb can i change the jets to give it more up top? i have 72/77 jets in it now
Old Oct 22, 2007 | 07:05 PM
IHI's Avatar
IHI
To find out where you need to be jet wise, forget looking at plugs, esspecially if you have a good ignition system, you'll increase jet until you might as well just pull the carb and put a gas can upside down in the intake...watch your mph, go up 2 sizes front/rear after 2 baseline passes and see what happens, if your mph increases, upjet again 2 sizes...if it falls a bit, drop back one and see what happens, if it's still slower then go back to best mph pass jetting. You cant compensate for undercarbing by increasing jets...you'll kill the performance earlier in the run. And you'll find too the bigger the carb the bigger the jet you'll run...more air needs more fuel.
Do yourself a favor before you start messing with anything and chasing your tail...borrow some real slicks so you DEAD HOOK everytime, otherwise if you cannot duplicate a time slip within .005 each run (not factoring in major weather changes) all your doing is wasting your time and energy since numbers will be tainted...so either try the relocation brackets and hope that makes those radial things stick each pass, borrow a set of real DOT bias ply slicks/full slick...either way, you need to have every increment on the track identical each run...if your spinnning, you are'nt going to get any relavant info to base changes on....I know a few guy on here are having luck with the radial things, but life is soo much easier by just installing the hoosier QT pro's...they'll hook on a poorly set up car on a poorly prepped track every pass...not to mention they last longer, 60' faster, and ET quicker than M/T et streets...that's been proven here too we turned all the diehard m/t fans against m/t once they finally gave the quick time pro's a shot...and i think you will too if you ever switch.
Old Oct 22, 2007 | 07:19 PM
intex1982's Avatar
i will get some for next yr. i need some 28 in tires
Old Oct 22, 2007 | 07:59 PM
IHI's Avatar
IHI
What are your trapping rom wise now? by all accounts 28" tires and 4.10 gears go together like peanut butter and jelly, just curious as to where your taching across the finish line currently?
Old Oct 22, 2007 | 08:17 PM
intex1982's Avatar
around 6000 for some reason other night it was really high like 6200
CarGuyDennis
137
Dec 6, 2016 11:02 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
86Base
Aug 8, 2015 01:34 PM
