Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What shocks and springs are you guys using? (6.90's & faster)
Old 11-21-2007, 04:34 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have been a quickest of 1.44 60' rolling out several feet before hitting the 210 shot. Has gotten 1.50's on MT Drag Radials before on motor. I'm using V6 rear springs and chopped and heated front springs. 90/10 shocks on the front and some crappy summit adjustable rear shocks. Thinking of going with Moroso trick front springs and Comp. eng. adjustable rears. Really want to hit the spray off the line. A 150 shot gave me a 6.72 @106 mph with a 1.47 60'.
Really want some input on some of your springs and shocks. Already have the Spohn TA and the LCA's.
Old 11-21-2007, 06:02 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: What shocks and springs are you guys using? (6.90's & faster)
do you have any lca relocation brackets yet? that'll definitely help if you don't have them already.
i'm just running stock front struts with like 220k on them and monroe replacement rear shocks, trimmed v6 springs, but i'm not making the kind of power you are.
Old 11-21-2007, 09:09 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
175lb spring up front on the 90/10 struts and a 150lb spring in the rear factory placed coilovers. 1.42 60 foot and roughly 6.45 in the 1/8th
Old 11-21-2007, 10:18 PM
car_fixer's Avatar
well i can foot brake a 1.36, and trans brake a 1.28, so i guess that qualifys me to answer right. I use koni spa 1's up front and moroso trick springs, out back factory rear v 8 springs and also spa1's on full stiff all the way around, i have made lower control arm relocation brackets so i can have some adjustability, also have a killer rear anti roll bar, the drag bar that they make will be ok for most cars, provided you at least have subframe connectors
Old 11-22-2007, 09:15 AM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Everything up front is stock, chained down with maybe 1" or less of travel. Stock V-8 springs on the rear with the Competition Engineering 3way adjustable stocks on 40/60. Spohn TA, Hotchkis LCA's in stock location and spohn rear drag swaybar. 1.395 60ft. n/a.
Old 11-22-2007, 10:23 AM
DIGGLER's Avatar
i am running the same exact setup on my car. 1.32 off the foot brake.
Old 11-22-2007, 05:59 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have had the spohn relocation brackets in the past when I had the 10 bolt. but since I put in the Moser 9" I haven't put them back on. May try those again and then get some Moroso front springs. Has anyone used the Strange Engineering adjustable rear shocks? They have a dial so that you don't have to disconnect them to adjust the setting.
Car_fixer do you like the drag roll bar? How much of an improvement did you see? Anyone else have any tips to hook the car on a big shot? Remember I'm using 255/50/16 MT Radials. Thinking of going back to the regular ET Streets.
Old 11-22-2007, 06:51 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Axle/Gears: 3.55
hey 1 bad 406 you run 5.14s how tall is you rear tire? i was running a 4.56 in my s10 on spray runnin 9.93 but it only crosses at 6500. i want it to cross at 7800 on the spray and lower on motor. im running 32" tall tires. im thinking i need a 5.67
Old 11-22-2007, 09:49 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
I run 28x10.5's with a glide.. 1.76 planitary I turn about 7000-7100 crossing the line in the 1/8th.
Old 11-22-2007, 10:31 PM
car_fixer's Avatar
my post was kind of confusing, i dont have the drag bar, i built my own, however the drag bar looks like a good setup to retain a fuel tank
thats mine, no way to use a factory fuel tank with it
the only problem with the drag bar might be the attachment points at the body, otherwise it looks like a good piece and the strange shocks are pretty good, how ever you adjust fronts more than rears, so dont get real hung up on that, konis on full stiff in the rear work pretty good , might need to loosen up for a rough track but chances are if you need to do that you probably wont want to run there
Old 12-23-2007, 09:59 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
I have SSM lift bars, with eibach drag launch springs and koni adjustable shocks and struts.......set the struts all the way loose, and have the rear shocks 1 click away from stiffest.......car launches pretty consistantly with good track prep, and straight as an arrow. theres some wheels-up pics if you go to my garage page.
Old 12-24-2007, 05:54 AM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
I have koni spa1 with 175 pound springs up front. Rear springs are stock with 1/2 coil cut and strange shocks. I'm also running the spohn drag bar on the rear since I still have the stock gas tank in the car. I have been 5.57 in the 1/8.
Old 12-26-2007, 11:19 AM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
What brand and where did you get the front springs? Are they the Moroso trick springs? Also, are the strange shocks the dual adjustable or single? How much do you think that the drag bar helped you? Thanks in advance.
Old 12-27-2007, 10:04 AM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
They are QA1 springs. I have coil overs on the front. Moroso trick springs or stock 6 cyl springs work well on the front if you wanna use stock style springs. I ran my stock 6 cyl springs well into the low 9's. The strange shocks are single adjustable. The rear drag bar is critical. Without it a hard leaving car will twist badly.
Old 12-29-2007, 02:24 AM
t-top89's Avatar
http://s3.photobucket.com/albums/y75...=TTAlaunch.jpg
7.20's on this launch. Bilstien shocks on all four and no swaybar...the rest stock. Now I have ford 9'' 3.25 gear ,26'' M&H cheaters, optional 30'' hoosier slicks, lots more power and in need of advise to launch like a pro kinda like this:
http://www.gofastfilms.com/DRAGRACIN...vens%20751.wmv
Old 12-29-2007, 12:17 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
That vid is awesome. Doesn't pull the front wheels at all.
Old 12-29-2007, 12:53 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
That car looks good in the video I believe that is a blow thru big block power. He was at Orlando this year.
Old 12-29-2007, 01:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
You need more anti-squat judging from your launch. I would either go with a jegs adjustable torque arm or LCA relocation brackets. You want the rear to stay the same height or actually extend slightly, but not far enough that the shocks extend all the way and then the rear will break loose.
Old 12-29-2007, 10:57 PM
car_fixer's Avatar
that pic also had lots of roll, i would definitly try some lower control arm relocators and a rear anti roll bar, even a stock one will help, a drag bar would be good if you have alot of power, I can run a foot brake and have like no movement other than foreword like this
and thats a 5.95 1/8, 9.29 1/4 1.36 60 ft
Old 01-07-2008, 01:47 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
QA1 coilovers with 175lb springs in the front with Tokico illumina 5 ways. The rear is stock springs, QA1 adjustable shocks, wolfe anti-roll bar, and everything else has been replaced with spohn adjustable pieces. No times yet, but should be good for 1.3's in the 60, car also has tubular kmember and a-arms.
customblackbird
08-15-2021 10:16 PM
LT1Formula
11-16-2015 01:13 PM
Street Lethal
08-14-2015 08:25 PM
1988iroc350tpi
08-14-2015 07:52 PM
1992 Trans Am
08-09-2015 04:32 PM
Quick Reply: What shocks and springs are you guys using? (6.90's & faster)
