Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
pics of nitrous setups
Old Nov 30, 2007 | 10:58 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Would like to see your guys nitrious install pics. Were do you guys mount them and how you run your lines to the motor pics would be great just trying to get an idea.
Old Nov 30, 2007 | 11:30 PM
car_fixer's Avatar
Re: pics of nitrous setups
I have a plate i fabbed up to hold the solenoids, and ran the lines down the right side, through the hole behind the kick panel to the engine.
brackets i made for wiring and nitrous line
Old Dec 1, 2007 | 06:43 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
what size are the ss braided nitrous lines? i was thinking about putting the botle in the hatch under the hatch cover and drilling a whole into the trunk pan and running the wires and lines along the frame rails being held on by the cusioned wire holders that you can screw into the frame. I thought the nitrous kits come with a solenoid bracket for the carb?
Old Dec 1, 2007 | 08:42 AM
urmomshot77's Avatar
Car: 83 camaro
Engine: 383 stroker
Transmission: TCI 3spd manual
Old Dec 1, 2007 | 04:24 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
URMOM Not trying to be rude but you should consider moving the fuel pump to the rear of the car for better performace from the pump I would use a relay to power it with also and mount the fuel preesure regulator in another spot also so that if you take your ride to the track you can pass a tech inspection also no more than 12" of rubber line. Looks good other wise.
Old Dec 1, 2007 | 09:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 12" of rubber fuel line is the least of his worries. The fuel pump and regulator can't be mounted on the firewall either to be track legal. You also can't have any rubber line going past the bellhousing unless it's shielded or steel braided.
A front mounted electric pump normally will work better at the rear but it's no different than having a front mounted mechanical pump attached to the engine. For street use, you'll never notice any difference. On the track, it may have a hard time pulling fuel to the front of the engine under hard acceleration.
car_fixer: Your fuel line running inside the car is a no no or is that an overly large NOS line?
Old Dec 1, 2007 | 10:34 PM
car_fixer's Avatar
thats a #6 nitrous line, the fuel line is under the car going to the regulators on the right side of that pic (left side of car)
i didnt like the supplied brackets, and i wanted to make a heat shield for the carb anyway, so i put the 2 together.
Old Dec 2, 2007 | 04:16 AM
Car: 83 camaro
Engine: 383 stroker
Yeah i know its kinda sketchy at the moment. But i havent been able to get around to it much in the last 7 months. Im stuck over here in Tallil, Iraq untill May. Should be back home just in time for spring. I got some Big plans though.
Old Dec 2, 2007 | 06:36 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
here`s a system I put together over the last winter....
Jegs solenoid holders with NOS cheater solenoids and plate...NOS purge kit also
Here is the 1 gallon cell, there is also a holley pump and fram canister filter mounted under the nose along with a holley fuel reg on the inside fender well for easy adjustments.
Here is a picture of the office, there is the NOS progressive unit, it is wired with the MSD igniton to retard timing once activated, also there is a master arm switch, bottle heater switch, fuel pump indicator and a purge button. A autometer nitrous pressure gauge is mounted along with the other componets on a piece of 1/8 aluminum, behind all that is the wiring to not allow the system to activate while on the trans brake.
finally there is the picture of the JUG and it`s aerospace bracket and NOS auto heater and blowdown tube.
Old Dec 2, 2007 | 07:38 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
GM I like the fuel cell mount setup, what is the frame connected to? When I mounted mine i had to point the cell outlets to the front, but after looking at the pic i may try to have it going the other way. BTW the engine compartment looks good.
Old Dec 2, 2007 | 08:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Looks like a real pain to pull those valve covers off with the strut tower brace over them.
Old Dec 3, 2007 | 05:54 AM
you betcha ....I`m going to add some roll cage up to the towers to ditch that brace
Old Dec 3, 2007 | 03:43 PM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
Old Dec 4, 2007 | 10:10 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Radialtireking-how do you like your carb return spring linkage? It looks like the newer style with the dual individual springs that have the bracket to mount on carb studs?
Is yours outragiously stiff? We installed the Jegs one on the S10 and it was almost a two foot deal to WOT, unhook one spring and it was better but nowhere what I'd call and easy pedal. I finally reconfigured and installed normal old spring inside spring like what came on the facotry 80's cars and man, back to the good ole light pedal feel again. We tried adjusting everything to get it to work out of box, but those springs were just tooo much as tension was applied.
Got a wee bit o cash hiding under da hood, looks great
Old Dec 4, 2007 | 06:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I noticed the dual NOS system and Moroso vacuum pump system.
Old Dec 4, 2007 | 08:51 PM
car_fixer's Avatar
i have the same return spring setup, from summit, and it works great, i actually used the stiffer of the springs that it came with, getting it on the throttle arm required some imagination though
Old Dec 6, 2007 | 07:35 AM
Car: 85 Camaro
Transmission: glide
Axle/Gears: 3.70
The return spring setup is from moroso. It came with soft and stiff springs. I have the stiff springs on it and I think it has the perfect amount of tension.
Old Dec 9, 2007 | 03:51 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
scott, that reverse shift pattern on your console is trick! i'm runing a fourthgen console, so i can't have one just like that, but i might just have to come up with something like that later on!
i personally like a stiff pedal. gives me awareness of where my foot is.
here's my return spring. it's made by Philadelphia Racing Products, the same guys that make the Jegster one(haha, no nitrous here ) :
Old Dec 9, 2007 | 08:25 PM
xfactor200289's Avatar
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
Axle/Gears: 9inch 3.50 gear
Heres pics of mine a lil dirty jus got it back togather
Old Dec 10, 2007 | 07:39 PM
6.LIROC-Z's Avatar
Engine: 6.0L LSX Carbed
Axle/Gears: 3.73 Strange 12 bolt
Heres some pics of my 100 shot. To all the guys that have there holly blue pumps up front move them to the rear asap, I had mine mounted in the same spot as XFACTOR and it did fine on the street and on the dyno but as soon as I got it to the track I had nothing but problems. Had it in the rear now for over a year with no problems.
Since I dont smoke I had a perfect place for the swithces, the ash tray
Old Dec 10, 2007 | 08:25 PM
Car: 1989 trans am
Engine: 402 ls
Transmission: TH350
have not had any problems with it yet it is just used for the nitrous, stand alone fuel system
Old Dec 10, 2007 | 08:38 PM
6.LIROC-Z's Avatar
Sorry I didnt see it was just for N2O
Old Jan 28, 2008 | 02:39 AM
thelusivetoilet's Avatar
i dig the gauges, whered you get them and are they for mechanical speedos or electric?
Old Jan 30, 2008 | 02:39 AM
thumper115's Avatar
Car: 1972 SS Nova, 1991 Camaro drag only
Engine: Stock 350, 355 w/12.5's
Transmission: 350 auto's
Axle/Gears: 3.55, 3.73
Ross with your regulator mounted that close to the Engine does it give You any problems?
Old Jan 30, 2008 | 06:59 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
No it works fine my understanding it is best to mount the regulators close to the source that is beeing used in my pic I was running the motor on the nitrous reg due to a bad fuel pump on the motor side. I run the holley reg on nitrous due to there abilty to maintain a contnant fuel pressure as where my mallory will move up and down a few pounds.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TheExaminer
Sep 6, 2015 11:40 PM
