Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Rollover valve
Old Jan 15, 2008 | 06:47 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Rollover valve
I've got my fuel cell mounted in the well of my '90, Im running a firewall too to keep it track legal and all. Next step is to run a roll over valve. I was looking at this one on summit, P/N SUM-220020 , Now If I ran that wouldnt I still need to plumb it so its outside of the car? Whats the best way to do this and what have you guys done? I dont like drilling holes in my car Thanks
Old Jan 15, 2008 | 07:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rollover valve
Yes it has to go outside the car.
All the rollover valve is, is a special fitting with a ball bearing inside it. When the valve is upside down, the ball bearing covers the hole to prevent fuel from coming out. It doesn't need to be below the bottom of the tank but can't be inside the car because it's the fuel tank vent. The downside to the rollover valve is that it will only shut off the fuel when completely upside down. If you're on your side, it will still leak.
There are simpler ways to do it. Put a -6 fitting in the front top of the tank or a 3/8" male brake line fitting. Install a hose on the -6 fitting or a 3/8 brake line on the BL fitting and make a loop in the line. The line still has to go outside the car and below the bottom of the tank.
The loop acts like a water trap you find under your sink. No fluid can flow around the loop if the car is upside down. If there's any fluid in the loop when rightside up from driving around etc and there's a suction inside the tank, the fuel will get sucked back into the tank.
Old Jan 15, 2008 | 07:53 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Rollover valve
Alright, thanks for clearing that up.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
