Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Build input
Old Jan 23, 2008 | 12:22 PM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Build input
Well my motor is at the machine shop so the build is starting. Just wanted to know what you guys though of this build.
400sbc bored .030 over to a 406
Callies Dragonslayer crank -3.75" stroke
Eagle SIR 5140 forged connecting rods - 5.7" rods
Speed-Pro powerforged pistons - should net 13:1 compression with 64cc heads.
Federal Mogul engine rebuild kit - Should include all the gaskets and bearings.
Cam - Lunati voodoo solid roller #60133
Heads - WP sportsman II's with some heavy porting done, valve job, SS valves, milled down from 66cc to 63cc combustion chambers, completely setup for the solid roller.
Weiend team G intake
Holley 750cfm HP series carb
What do you guys think?
Old Jan 23, 2008 | 02:40 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
Re: Build input
you're gonna need more than a 750 cfm carb, that will choke it up. A 950 would work alot better.
Old Jan 23, 2008 | 03:03 PM
Engine: 406sbc
Transmission: TH400
Re: Build input
Well I have a 750 right now but I'll deffinatly be looking into a 850 or 950
I'm torn between the Eagle 5140 rods and the Lunati 4340 street rods, theres about a $200 price diffrence but are the Lunati rods that much better?
Last edited by 85Firebird350; Jan 23, 2008 at 03:06 PM. Reason: Automerged Doublepost
Old Jan 23, 2008 | 05:22 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Build input
That cam is asininely small for a 13:1 400, extremely poor choice in my opinion...
Old Jan 23, 2008 | 05:26 PM
Engine: 406sbc
Transmission: TH400
Re: Build input
With 1.6 rockers it'll have like .624/.630 lift, thats plenty of lift. Do you mean duration wise?
Old Jan 23, 2008 | 05:37 PM
Car: '89 IROC-Z
Re: Build input
That cam is suited for a 10.5:1 350-383 not a 13:1 400.... I'd imagine your DCR would be so high you'd have to run C16 all while losing 80+HP compared to a properly sized cam. Also, if you're buying a Callies Dragonslayer crank why on earth would you put that anywhere near a crappy 5.7" Eagle SIR rod and Speed Pro pistons?
Lastly, what do you plan on doing with this motor? with 13:1 I'd assume it's an all out drag car?
Old Jan 23, 2008 | 05:42 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Re: Build input
I am with 88 iroc on the rod deal but hay we all have differnt budgets. I perfer to spend better money in the rods. Can some one post the cam specs?
Old Jan 23, 2008 | 05:47 PM
Car: '89 IROC-Z
Re: Build input
110LSA/106ICL
Lift: .585''/.600''
Adv. Duration: 278°/285°
Duration @ .050'': 249°/255°
Solid Roller; Rough idle. Excellent cam for Street/Strip
applications has good mid range and excellent upper RPM torque and horse
power. Needs 3200-3500 RPM stall converter, headers, 10.5:1 compression
ratio or better and 4.10 gearing.
Old Jan 23, 2008 | 06:03 PM
Engine: 406sbc
Transmission: TH400
Re: Build input
I dont mind spending money on a proper engine thats why I asked about it. The rods most likely will be Lunati 5.7" street rods.
Old Jan 23, 2008 | 06:34 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Re: Build input
Use a flat top piston no need for the dome dont bother cutting the heads. I would zero deck the pistons. use .038-.040 head gasket keep the cam you picked with the 1.6 rockers make sure to use a 7/16 studs for the rockers and a girdle would be nice but not a must have. Also make sure you have a 30 deg back cut put on the int. valves it will bring your low and mid lift floe #s up. And your lifts with the 1.6s will be I.624 E.640 Yes get the lunati rod the 4340 is a better material.
Old Jan 24, 2008 | 10:21 AM
Engine: 406sbc
Transmission: TH400
Re: Build input
Would that cam be better in the 406 I already have built with 11:1 compression?
I upgraded my rods to Eagle H-beam forged 4340 rods. Theyre rated at 700 hp and 7500 rpm.
Old Jan 24, 2008 | 05:36 PM
Car: '89 IROC-Z
Re: Build input
With a true 11:1 SCR that cam would give you a DCR of about 8.8:1 ..."They" say you cant go over 8.5:1 if you plan on running 91 octane pump gas, especially with iron heads. If you live in an area with 93/94 octane you might be alright, still could be iffy.
Old Jan 24, 2008 | 06:14 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Re: Build input
Yes if you have a short block with flat tops in it will work I would have it zero decked and debor the pistons and cyl head chambers.
Old Jan 24, 2008 | 06:20 PM
Engine: 406sbc
Transmission: TH400
Re: Build input
Yes I have a 406 in my car with flat tops and a 406 block that I am building...hence this thread. We do have 93 octane here.
Jorlain
Oct 8, 2015 01:57 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
morrow
Fabrication
Sep 14, 2015 09:01 PM
