Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
1/4 mile e.t.estimate please
Old Jan 25, 2008 | 08:42 PM
jeff lucas's Avatar
Car: 92 camaro rs
Engine: 383 stroker (518 hp)
i have a gutted 92 camaro rs that is getting a 355 with approx 525-550 horsepower(says the builder), a muncie 4 spd that i'm in the process of trying to find, and a 4.10 in the rear, 200 shot of nitrous, sfc's, and slicks. thanks, jeff
Old Jan 25, 2008 | 09:16 PM
jeff lucas's Avatar
Car: 92 camaro rs
Re: 1/4 mile e.t.estimate please
come on someone answer, this ought to be a no brainer for u pros out there......am i gunna be fast, say im gonna be fast!!!
Old Jan 25, 2008 | 11:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You want to know what it runs? Take it to a dragstrip and find out.
Get me a chassis dyno HP number and a race weight and I'll tell you what it should run.
Old Jan 26, 2008 | 10:13 AM
85Firebird350's Avatar
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
3250 with 530rwhp?
Old Jan 27, 2008 | 09:39 AM
jeff lucas's Avatar
Car: 92 camaro rs
yes i would say about 3250 on the weight with 615rwhp
Old Jan 27, 2008 | 10:37 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
9.90 - 10.20
Old Jan 27, 2008 | 11:05 AM
jeff lucas's Avatar
Car: 92 camaro rs
that is great, i can't wait to finish this car, this is going to be fun, thanks for the reply!
Old Feb 10, 2008 | 09:22 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Say GOOD BY to that muncie, when you find it. It won't last too long. 600 hp and muncies don't mix too well. You better have plenty of cash, and learn how to build them your self. At least they do make parts for them now. Good luck.
Old Feb 28, 2008 | 12:23 AM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
So around 650 to the wheels with the 200 shot, around 3200 lbs, I would say 10.50s through that muncie.
Old Mar 3, 2008 | 04:18 PM
jeff lucas's Avatar
Car: 92 camaro rs
well the motor size has changed, instead of it being a 355, al pitre with pitre race engines decided to give me a 383 stroker for the same price. a little more horsepower but a lot more torque. is there a big enough difference in these two motors to make a difference. i dont have the particulars on heads, cam and such but he said probably about 20 more horse and 70 more on the torque. 1 more thing should i go with these urethane motor mounts and if so where can i get them, i have searched the internet and cant seem to come up with them.
Old Mar 3, 2008 | 04:25 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
if you are seriously putting down 600+ at the wheels, dont mess with urethane motor mounts.. put some solid mounts in and never worry about it again.. it will also give you a bit more power at the wheels..
unless you can bang gears, i say you run 10.3-10.5 with 600 at the wheels..
EDIT: one more thing. i would recommend some MSD electronics for the nitrous. you dont want to powershift with the nitrous running.. i would get a W.O.T. switch controlling a window switch.
Old Mar 3, 2008 | 05:01 PM
Engine: 406sbc
Transmission: TH400
600 at the wheels is a helluva ot of power from a 383. I could imagine 600 flywheel since my "mild" 406 is pushing 573 flywheel but that means something like 680 flywheel from a 383.
Old Mar 3, 2008 | 05:07 PM
Mike305RS's Avatar
I think he is saying 600 on the spray, not all motor.
Old Mar 3, 2008 | 05:11 PM
jeff lucas's Avatar
Car: 92 camaro rs
the motor itself will make around 570 or so when he's finished, he will be doing the break-in and dyno runs so i will know exact numbers later, i figured on the 600 horse to the wheels after the nitrous gets in there, all of this is a complete guess, completely theorical until i get my dyno numbers. those solid mounts are they as rough as people say they are. i heard it could make the car vibrate so bad nuts and bolts start loosening up?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
