Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
ET guesses???????
Old Feb 28, 2008 | 08:15 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
ET guesses???????
Yeah, I know its been done hundreds of time before and I'll have real numbers by mid april...
Last years #'s are in sig. (Only 2 trips to the track to try and tune)
Staying the same
9.5:1 350 (.060)
Ported 416's with 1.94 intakes
1 5/8 LT's
Upgrade cam from a 10yr old erson grind cam 224* .472" to Lunati Voodoo 60103
Change intake from Weiand single plane to RPM Air Gap
Upgrade stock suspension to Moroso Trick Front Springs and Lakewood 90/10's and rear from stock to Alston Race Cars T/A and LCARB's
Remove 75 lbs. (Mostly from the front)
3.73 gear
3500 stall in a th400
28x9 slick
I know that it won't be worth a bunch...but hopefully a few tenths
Old Feb 28, 2008 | 08:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: ET guesses???????
old cam details?
Old Feb 28, 2008 | 08:39 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
224*@.050 .472" lift 108 lsa
Forgot to mention going from 650 DP to 750 ( found some problems with the 650 main body)
Old Feb 28, 2008 | 08:41 PM
xpndbl3's Avatar
Car: 1984 Z28
so what is the new cam specs compared to the old? you listed the same specs twice in a row now.
Old Feb 28, 2008 | 09:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
voodoo is 268/276 227/233 with 489"/.504" valve lift, and 110 lsa
that should pick up with the rpm air gap and the 750 carb. I think your old seutp should have been faster than what you ran, depends on the head porting. if not ported alot they are holding you back.
this new setup should go lower 12's at 108-110 i'd say well tuned if those heads are ported decently
Old Feb 28, 2008 | 09:40 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
I took the ports as far as I would dare take them. I'm sure alot of guys have taken them farther, but with the old 305 the port and valve change was worth 5 mph.
Thanks for the input!
Old Feb 28, 2008 | 10:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
that motor should run pretty strong
Old Feb 29, 2008 | 08:27 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
I'd like to be optomistic and say with a good tune and good air a 12.0 is possible. I'm hoping that the suspension upgrades should help to drop my 60's by a .1 - .15. I changed some of the fuel system out this winter as well, the car was starting to cutout @ around 5500 last year after switching to the 350, also changed out the HEI module just to eliminate that as a problem, I should have some hard numbers on opening day (April 12)
Old Feb 29, 2008 | 09:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you should have alot left in that 60 foot
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
