Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Help Breaking 12's...
Old May 14, 2008 | 09:29 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Ran my 92 RS last night at Atco, NJ and just couldn't get in to the 12's. I was hoping that the 150 shot that i just installed would push it into the 12 second index but i came up just short at a best of 13.060. Info is below. Suggestions please!
Without 150 shot:
R/t: .363
60': 1.986
1/8: 9.043
1000: 11.82
1/4: 13.98
Mph: 97.46
With 150 shot:
R/t: .293
60': 1.768
1/8: 8.33
1000: 10.89
1/4: 13.060
Mph: 103.78
Old May 14, 2008 | 10:44 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Re: Help Breaking 12's...
DETAILS! Whats the rest of the combo?...ALL OF IT!
Old May 14, 2008 | 11:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
150 shot only got you almost a second and only 6 mph? figured it be higher than that and quicker ET wise with 150 more hp
your 150 shot time looks good tho for the power at 103mph. My 12.95 run looks like that sorta. 1.71 60 foot, 8.21 1/8 , 10.79 1000 foot, and a 103.8 mph trap speed.
Old May 16, 2008 | 08:20 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
350 bored .030 over, vortec heads, gm aluminum intake, comp cam - .425 intake lift .440 exhaust lift, edelbrock shorty headers, flowmaster super40 exhaust, 2400 stall converter, shift kit, larger TBI injectors, 3.42 posi rear.
need any more details?
Old May 16, 2008 | 08:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
whats the duration on the cam? and compression?
hows the tune with and without the shot?
Old May 16, 2008 | 08:52 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Duration: Intake - 252 Exhaust - 260 (if im reading my cam card correctly)
Not sure about compression
Tune is very good.
Old May 16, 2008 | 09:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats a pretty mild cam, so the n/a time seems ok for the mods. Its a TBI car still correct as i seen TBI injectors listed
I'd be happy with those results on motor for now. How heavy is the car? your gonna hit 12's with the shot with a little better launch and good air/weather. YOu probly could use more stall but with the shot, that 2400 should act like a 2600 or so.
Keep an eye out on the density altitude and air temp/humidity. Track that information and run when it looks as good as it will get in your area and you'll see good times
Old May 17, 2008 | 09:27 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
assuming you have at least 9.5:1, swap in a bigger cam (like Comp XE268) and go carb... you'd easily run 12.80-13.0's on motor and 11's on the 150 shot.
Old May 17, 2008 | 12:16 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
yeah i was considering a carb swap a little bit ago actually. thanks for your input
Old May 17, 2008 | 12:21 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I'd be really surprised if your injectors weren't going static at ~4500 rpms. Are they 454 injectors?
Old May 17, 2008 | 03:49 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
i believe so. and what do you mean by static?
BTW i checked the nitrous jet today and it is a .047 jet which is a 100 shot i believe not a 150 shot.
Old May 17, 2008 | 04:13 PM
badsonic's Avatar
Car: 84 Berlinetta
Engine: 360
Transmission: 350 turbo
Axle/Gears: 9"/4.11
3.73 gears for sure will help get you there!
Old May 17, 2008 | 04:37 PM
DirtyCanadian's Avatar
What do you got for a transmission 400 hp dont mean jack if your transmission sucks.
Old May 17, 2008 | 06:16 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
700R4, stock except 2400 B&M Holeshot converter and B&M Shift Kit
Old May 17, 2008 | 11:21 PM
327???'s Avatar
100% duty cycle, open 100% of the time. Meaning that once they go static it just keeps getting leaner and leaner.
Old May 19, 2008 | 07:52 AM
86 IROC's Avatar
Do you have a bottle heater? Did you keep track of bottle pressure during the runs? When did you start spraying?
A 100 shot on my 2000 netted me .9 and 8.5 MPH on a very hot & humid day. I picked up 12-13 MPH on a 150 shot, picked up less than a second because of wheelspin.
Old Sep 29, 2008 | 12:34 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
bringing this back from the dead,
no bottle heater.
pressure at around 900psi
nitrous is activated at WOT
Times posted above are for a 100 shot not a 150 shot (typo)
Picked up 6mph and .92 ET on a 100 shot.
What should i be expected to run with a 150 shot? (planning on running it next week sometime.)
Old Sep 29, 2008 | 12:44 PM
86 IROC's Avatar
no bottle heater.
With traction, you "should" see another .3 -.4 on the bigger pills.
Old Sep 29, 2008 | 12:46 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
thumbs up for the quick reply.
anyone else out there?
Old Sep 29, 2008 | 01:18 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
What do you have for a suspension setup?
Old Sep 29, 2008 | 01:30 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
u need to go carb. u'll pick up .3-.5 just off that i think
Old Sep 29, 2008 | 03:25 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
spohn rear LCA's and Panhard rod, KYB gas a just shocks. Thinking about buying some LCA relocation brackets to help with the 60'. getting some spin off of the line. see for yourself:
http://www.youtube.com/watch?v=TggnR-PQtw4
Old Sep 29, 2008 | 06:30 PM
SLP_GTA's Avatar
hard to tell in the dark, but LCA relocation brackets help bigtime
Old Sep 30, 2008 | 06:48 AM
86 IROC's Avatar
What are you using for tires?
Old Sep 30, 2008 | 12:36 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
m/t dr's
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
J.C. Denton
Sep 21, 2015 04:23 PM
