Rear shocks
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Rear shocks
I was wondering is the lakewood 50/50 rear shocks are good on the street or not. The car is street/strip and I am more concerned with traction instead of cornering but dont want to sacrfice to much. Any input on front struts and rear shocks for good traction but still a little bit of driveability is appreciated. Thanks
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: Rear shocks
i run lakewood 90/10s up front and they're awesome at the strip, but they pretty soft for street driving.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Re: Rear shocks
i run lakewoods up front but mines more strip than street...soft but solid id say. i run comp engineering shocks out back. its been a strong street/strip setup
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Rear shocks
i had lakewood 50/50's in the rear of my 89 and it drove like stock on the street but those plus LCA's (cheapy lakewoods) drop my 60 ft .2 on regular street tires, not to mention the car stopped wheel hopping. You can actually run fox body mustang strange 10 way adjustables on an fbody and they only cost $70 a piece!
Re: Rear shocks
Thanks for the replies. A question about those mustang adjustable shocks. Are there any modifications when using them? Do you know the exact model number? Will it be the correct size so there is no change in ride height or anything like that or is it pretty much a direct bolt in job? I like the fact that I have the power to adjust for street in strip with the same price tag.
Thanks again.
Thanks again. Trending Topics
Car: 91 z28
Re: Rear shocks
As far as i know, there is no modifications to run them in an F-body. There is only one part number for a 79-93 mustang strange 10 way shock, so there shouldnt be any confusion.
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: Rear shocks
I have lakewood 50/50 rears shocks on my 82 their fine on the street, there a little stiff, It rides a little bit rougher than stock.
Re: Rear shocks
Thanks for the replies. I might just go with the lakewood 50/50's but if someone definitly knows the strange fit directly in with no problems then I might go with the strange. Do they actually have the same fully extended and compressed lenght I couldnt find that info? Also a little tough to put a mustang part on my car lol. Thanks again
Re: Rear shocks
t-bird shocks would be the right length, we used to do that with Koni's for autox because they were slightly softer and worked better than the f-body ones (which worked better for road racing). Strange might not have a separate t-bird part number which would make the mustang ones next closest.
Car: 91 z28
Re: Rear shocks
Re: Rear shocks
83 Crossfire TA you said t-bird would be the right length so those are not? will that effect ride height? Thats what im mainly concerned about. I know wheelsup84z said someone had them on here but who knows there car could be all jacked up in the back as well though. If any one has extended and collapsed measurements for them that would be awesome. Thanks
Re: Rear shocks
Alright I talked to strange today and found out the dimensions of the shocks. Fully extended is 19.3 and collapsed is 13.0 for the mustang 10 ways. I also found out what the lakewood 50/50's are and they are 20.13 extended and 12.050 collapsed. So I would lose a little over 3/4's of an inch in extension and pretty much an inch when collapsed. So thats about almost two inches of travel. Im not a big shock expert so I dont know if this is a problem or it is no big deal if someone would let me know what they think about the travel it would be much appreciated. Thanks guys.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Rear shocks
how often does your rear drop down 6" or so while driving? I don't see losing an inch at extension being an issue
Jack up the car by the lca mount in front and see how far the rear drops that would never happen while driving.
Jack up the car by the lca mount in front and see how far the rear drops that would never happen while driving. Supreme Member
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Re: Rear shocks
Had my lakewood 90/10 struts up front and lakewood 50/50's on the rear for, 4 or 5 yrs now?? drives fine on the street and if driver does'nt screw up, always brings home money every weekend.
cheap and they work, how much more you want...10 way adjustable...10 more ways to mindf..k yourself.
Re: Rear shocks
I like the way your looking at it IHI why complicate it when many people on here are running the lakewoods with great success so thats what im going to do. Thanks for the help guys.
Re: Rear shocks
WRT to the length... I wouldn't be suprised if you saw more of a difference going from one manufacturor to the next with the same application.
The bigger difference is the dampening rate. Mustangs tend to run lighter and have a slightly more advantagious shock mounting point than f-bodies, which is the reason to go with the t-bird shocks... they're closer than mustangs, even though they're still softer than f-body shocks.
LT1Formula
Nov 16, 2015 01:13 PM
