'88 L98
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: '88 L98
I ran a 14.04 on a hot day with street tires and exhaust (1.75" primary SLPs and pieced together 3" catback). So I'd expect 14.3 to 14.5 is very achievable in bone stock form.
Car: '90 Camaro RS, '94 Miata, '95 F-250
Engine: 5.7 TBI V8, 1.8 PFI L4, 7.5 PFI V8
Transmission: 4L60-OD, 5spd Std, 5Spd Std
Axle/Gears: 2.73 Posi, 4.10 LSD, 3.55 Posi
Re: '88 L98
Mine aint no where near stock, but it is a V6 and I run 14.18 @ 95.8 on a hot day on the second pass...I usually run 14.19-14.23's...
3.4 Liter GM Performance Parts Crate Engine
Ported and Polished Heads, Intakes, and Throttle Body
Crane PowerMaxxx cam (.427/.454) and hydraulic lifters
Accel 19lb Injectors
Accel High Volume Fuel Pump
Accel High Flow Fuel Filter
Accel U-Groove Blister Pack Plugs
Accel Super Stock Plug Wires
Accel Brute Thunder Coil
GM Performance Parts Roller Tip Rockers
Hypertech performance control module
Specter cold air intake
Random Technologies High Flow Cat
Flowtech Terminator Muffler
B&M Stage 2 Shift Kit
B&M Shifter
B&M Shift Cable
Bilstein street stock shocks
WS6 Suspension
Lakewood Panhard rod
Edelbrock Torsion Bar
Bilstein Street Stock Struts
Energy Suspension Bushings
Energy Suspension Motor and Transmission Mounts
1LE aluminum driveshaft
3.08 Positrack rear end
B&M Shifter
B&M Shift Cable
WS6 Suspension
