165 shot of nitrous + stock diff = bad
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
My best time on a 145hp shot was 11.0039 @ 125mph, 1.55 60ft. This was on the stock gm 10bolt diff(only thing I did was weld the axle tubes and put a TA diff cover on)
I wanted the "10second" slip bad so I upped the juice.
I hit the nitrous out of the hole too, here is the result.
The "TA" aluminum diff cover
First thing I saw when I took the cover off
The pieces that I took out
The end result
Good thing I was the last car of the day and the last race of the year!!
Time for a ford 9"
The end result
Time for a ford 9"
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: 165 shot of nitrous + stock diff = bad
ouch!...i hope my rear doesnt ever do that....was that a stock unit? ive got the zexel..hoping it holds better than that.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Oh yea, this was my second pass, i was going to hit the nitrous in 2nd, i never made it out of first, this is a richmond 4.10 gear.
Car: 1987 Trans Am
Engine: 355
Transmission: Th-400
Axle/Gears: 4.56 Richmond Gears
I had one do that with a stock motor and about 250,000 or so miles when I got it. I done one burn out then it made a bad sound and locked up, gotta love a 10 bolt
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
now all the kids can see what the inside of a posi looks like! you guys make me nervous....hope mine doesn't do that before i get a 9 inch
Car: 1991 Camaro RS
Engine: 555ci BBC
That sucks....
I used to have a 1982 Indy Pace car that had a 406 with the stock rear end and would spray that with a 250 shot running 10.50's and all I would have to do is replace the gears and bearings every year.
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Ouch!!!! that sucks!!!! What does a tow from Gimli cost by the way....? Just in case I break something next year.
It's bad when you hope to run so strong that you expect to break things
I have to get bigger injectors and a tune first, cause my AF ratio was way too lean to drive let alone do a 1/4 mile.
Do you plan on doing the ford 9" yourself?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Although they are much stronger, a 9" is not indestructible. Here's what I did to mine earlier this year. I caught it before it failed and caused any damage. A light tap with a hammer and the piece broke right off.
I threw in a spare center section to finish off the season. I have a Moser aluminum center section just waiting for a different set of gears before I swap it out.
It's those 6000 rpm transbrake launches that caused problems
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
jeez, i've been spraying mine with a 150 shot but not out the hole, i give it a good 40-50 ft before i do anything
still doing 1.5-1.6 60 foots and its still holding strong. hope my luck doesnt run out
I always hear its the carrier that breaks alot and not always the ring gear
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
You guys are lucky, i ate up 4 rear ends (lucky i had a buddy that parts out these cars so rears were readily available. 1 two yrs in a row, then 2 in one season...and that was back when i was running 12's-13.00
spun the teeth clean off the ring gear every time.
spun the teeth clean off the ring gear every time. Supreme Member
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
So then what is the best diff, w/o breaking the bank.
Car: '82 Z28
Probably pick up a Rockwell 2 1/2 ton for not very much...... lol
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Anybody got failure stories on a 9 bolt? I just put 4.11's in it and plan on hitting it with the juice. It it fails, I won't be able to get parts for it.
Took a tooth clean off. You could hear the tapping sound on the ring gear when the gap in the pinion passed by. Not knowing exactly what the damage was, I made another dozen passes, however traction was starting to go away and I never laid down the same 60'. Probably saved the rear from shredding completely.
Still drove it another 300 hiway miles in a round about way home and somewhere along the way another tooth broke off and things got really noisey. Got home under my own steam though.
I had a spare differential in my shop and removed the ring and pinion from it.
Had to change from 3.70's to 3.27's.
Lots of choice if you want to buy an offshore gear set like Motive Gear ( which I won't do ). If you want to spend the extra dough you can pick a USA gear set for about three times the cost.
My understanding is that the 9 bolt isn't worth the dollars on gears and rebuilding.
Can you say Moser?
Can you say Moser?
Car: 89 Iroc-z
Transmission: TH400
broke the spyder gears in my 3.27 9 bolt on a high 13 second pass. was cuttin 1.7x 60 foots on it tho
couldnt find parts and got a 10 bolt LS1 rear end complete for 300 bucks. less than 30K miles on it. Holding up great so far
CarGuyDennis
137
Dec 6, 2016 11:02 PM
