Fuel cell rule
Subscribe
Nov 15, 2008 | 11:42 PM
Whats the rule on a front mounted 2-3 gallon fuel cell mounted under the hood? Looking to put it where the battery used to go.
Reply 0
Nov 16, 2008 | 12:39 AM
Re: Fuel cell rule
Same as any other fuel cell rule. No more than 12" of rubber fuel line. Hard line or steel braided hose only.
If located outside body and/or frame, it must be enclosed in a steel tube frame constructed of minimum 1-5/8" x .118 tubing.
Although in the battery box area is technically outside the frame, it's up to your local tech inspector if it's acceptable without a frame around the outside.
Reply 0
Nov 16, 2008 | 05:36 PM
Re: Fuel cell rule
Mine is mounted in front of the radiator support, and while my tech guy never said anything, I did make up a bar that goes qround the front and attaches to the front with plates that bolt up where the front crash bar was located.
Reply 0
Nov 16, 2008 | 05:56 PM
Re: Fuel cell rule
Since I need to get a chassis certification next year, I'm planning on doing something similar.
Reply 0
Nov 16, 2008 | 06:48 PM
Re: Fuel cell rule
Quote: Same as any other fuel cell rule. No more than 12" of rubber fuel line. Hard line or steel braided hose only.
Is that total or in one section? I have a car that came from the factory with rubber fuel lines going to each injector, 6 injectors x 3" per = 18" of rubber line. Local track probably wouldn't even look twice at it though.
Reply 0
Nov 16, 2008 | 09:15 PM
Re: Fuel cell rule
But those are not rubber hoses. They are pressure lines so they're already reinforced. I have 8 similar rubber lines going from my barrel valve to each injector for about 8-10 feet of hose.
The rule book says 12" total. This accounts for all the small sections of rubber hoses joining a fuel pump, filter, carb etc to hard lines.
It was/is very common from someone with a chev engine to replace the hard line from the pump on the side of the block all the way up to the Holley carb they just installed with a chunk of plain rubber hose. This isn't acceptable.
Steel braid hose is an option but there are other types of pressure hose that's also acceptable. Woven pushlock hose is a pressure rated hose that's also acceptable and isn't steel braided.
Reply 0
Nov 17, 2008 | 12:37 AM
Re: Fuel cell rule
Quote: But those are not rubber hoses. They are pressure lines so they're already reinforced. I have 8 similar rubber lines going from my barrel valve to each injector for about 8-10 feet of hose.
So it basically has to be pressure rated?(70-80ish psi)
I'd bet that my local track won't open the hood, but it's good to know if they ever start enforcing the rules.
Reply 0
Nov 17, 2008 | 08:13 AM
Re: Fuel cell rule
Buy a rulebook
Reply 0
Nov 17, 2008 | 11:52 AM
Re: Fuel cell rule
Quote: Mine is mounted in front of the radiator support, and while my tech guy never said anything, I did make up a bar that goes qround the front and attaches to the front with plates that bolt up where the front crash bar was located.
got any pics of that?
Reply 0
Nov 17, 2008 | 01:41 PM
Re: Fuel cell rule
the rules state that individual injector lines are excluded
Reply 0
Subscribe
