Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Road race thirdgen!! Pics wanted
Old Apr 16, 2016 | 10:47 AM
  #501
Rockwall's Avatar
Re: Road race thirdgen!! Pics wanted
500 hp, 500 lb torque
Old Apr 16, 2016 | 10:51 AM
  #502
Rockwall's Avatar
Older video in light misty rain of my Camaro at smaller autocross venue.
Old Apr 16, 2016 | 11:28 AM
  #503
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Originally Posted by Passmenow
corkscrew, feels like you got it all when the rear tires bark coming off the hill.
2014 Reunion GTP/GTO Thursday. - YouTube
That's awesome! I've spent hundreds of hours motherf¥£€ing that track from a 2 dimensional perspective playing games and always had the dream of running it for real in my firebird.
Much respect!
Old Apr 16, 2016 | 11:03 PM
  #504
Passmenow's Avatar
Car: Trans Am/IMSA GTO Camaro.
Engine: V8
Transmission: Weisman 5 speed.
Axle/Gears: Winters w/ Torsen Gleason 4.11
Originally Posted by 91banditt2
I've spent hundreds of hours motherf¥£€ing that track from a 2 dimensional perspective playing games.
I just started Iracing on a sim to keep the rust off.
The Camaro and the Iracing 5 year old Australian super car has about the same shift points and lap times.
I use paddle shifting only on the sim.
The Laguna Seca track on Iracing felt just like the real track.
Even saw some of my real track reference points, painted lines and telephone poles.
Down the front straight over the blind hill, keep it full throttle and aim at the telephone poles far ahead on the right.
Nice hotrod Rockwall!
Old Apr 17, 2016 | 12:50 AM
  #505
Dscott's Avatar
Car: 89 Iroc street car
Engine: Fitech vortec 400sbc/T5
Transmission: Also 69 Chevelle, Nascar chassis
Axle/Gears: 700hp roadrace track day car
Originally Posted by Rockwall
1986 Camaro 355 ci turbo hydramatic. Dedicated autocrossed, with other potential.
Love it, awesome . Is there a build thread? or a chassis rundown?
Old Apr 18, 2016 | 11:12 AM
  #506
Rockwall's Avatar
For Sale – 1985 Camaro Z28
Brief Summary: 1985 (3rd generation) Camaro Z28 – Victory (Tahoe) Red. Light flames. 355 professionally built engine. Turbo 350 automatic. 10 point professional cage & subframe connectors. Ford 9”. –Rick Walford – 719-three three two – 4508, ricwalford”at”aol.com
355 professionally built engine –MSD ignition. Brodix Track II intake/aluminum heads. Custom headers. Electric water pump/fan/Aluminum radiator. Remote oil filter. Race type power steering pump. Mini starter. . Engine block an early high zinc content truck block.
Holly race prepped four barrel. 8 gallon fuel tank. Holly fuel pump.
Automatic – Turbo 350 3000 Stall converter with remote cooler. B&M slap shifter.
4.56 gears in custom axle housing Ford 9”. Tru-Trac differential.
12:1 ARE steering box replacement.
10 point professional cage with integrated subframe connectors, engine bay cross brace and door entrance side tubes.
Lexan windows, fiberglass cowl hood. Gutted doors with brace open and close. Metal fender flares. Aluminum rear deck.
Weight 3070 . Car weighed 2700 when completed but with 355 and 12” rims minimum weight is 3030. Lead ballast added on rear passenger floor. Weight is 52% front and 48% rear. With me in car was 1 lb difference right to left and 25# heavier on left front than right.
12” Weld Wheels with Original offset Z28’s had (front and rear different). Hoosiers (bias) on there now and has about 30 runs on them.
Baer Front brakes, spindle and rotor kit from Barer road race kit. Willwood discs on rear. Willwood brake cylinder. Separate cylinder for front and rear brakes. Brake bias.
Passenger aluminum seat. Optum battery. MSD box and distributor.
Herb Adams – suspension, Global West metal bushings, Eibach springs adjustable spring perches. Trac-bar (sprung traction bar). Basically the car still has strut suspension, Koni yellow single adjustable front struts, through caster/camber plates. Rear shocks 3 way Koni Yellows. Front lower A-arms have perched up ball joint housing to help bump steer and angle geometry.
Old Apr 18, 2016 | 01:03 PM
  #507
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
I posted this in the for sale section but maybe it needs to be in here as well. I wish I had the money to devote to this...it would be an awesome project and a cool car to just have in a finished state. Not to mention, what a hell of a deal for all the stuff you get.
http://tampa.craigslist.org/hil/pts/5506961531.html
Old Apr 18, 2016 | 08:41 PM
  #508
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Old Apr 19, 2016 | 09:03 AM
  #509
Dscott's Avatar
Is this your car? Ive had this pic for years
Old Apr 19, 2016 | 10:18 AM
  #510
BADNBLK's Avatar
COTM Editor
Colorado car. I remember seeing this on craigslist. Still got it?
Old Apr 19, 2016 | 11:54 PM
  #511
Dscott's Avatar
"Offset chassis" means upwards of 64% of the weight of the car is on the left side. Really good for an oval car, not so good if you want to turn left and right! just sayin'
Old Apr 22, 2016 | 10:43 AM
  #512
Car: 1991 Firebird
Engine: 3.1L V6
Thanks for just sayin'. Learn something new every day. I figured something was different on the chassis just wasn't sure how.
Old Jun 22, 2016 | 06:55 PM
  #513
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Old Jun 22, 2016 | 07:04 PM
  #514
morrow's Avatar
Car: 92 Camaro Rs.R
Virtually everything on this car is made one off... The suspision is all built from scratch.. Including the coilover internals front and rear upper camber plates as well as the adoptable ride height strut to spindle mounts . Lower control arms are custom made with a stretched width to add a few inches on each side pushing the total width of the front track over all 6 inches wider than stock... Using a 4th gen rear and matching suspension in the rear with 1.25 spacers to match the front width. I'm running 295 30 18 r888 front and rear and I love them... As for sway bars I'm using the hotchkis big bar up front and an iroc rear bar. Splitter, spoiler, blown diffuser and hood Louvers also made from scratch
Old Jun 23, 2016 | 10:56 AM
  #515
83RDRACR's Avatar
Morrow, great work on all your mods. We have all been looking for GOOD, WORKING examples of splitters and diffusers, and front suspension mods that would allow us to run wider tires up front and also give us add adjustability. It looks like you have developed some very marketable products for the 3rd gen community. If the quality is good and they are priced reasonably you could sell quite a few of your creations.
Dave
Old Jun 23, 2016 | 06:16 PM
  #516
morrow's Avatar
Car: 92 Camaro Rs.R
Dave
Thanks Dave . . . Currently I am building the hood lovers and wicket bill spoilers to sell.. The diffuser is still being tested but I am will to build and sell them.. As for the splitter.. That all depends on how many people are willing to spring for one, 1000 a peice with turnbuckles and upper weld in mounts... Each one is 32x68 inches 100%carbon fiber hollow core.. I'm not sure how well it would mount up to the 80's body graphics though due to it being molded to the 92
Old Jun 27, 2016 | 04:03 PM
  #517
morrow's Avatar
Car: 92 Camaro Rs.R
Old Sep 30, 2016 | 12:29 PM
  #518
rkkgto's Avatar
Car: 1987 Z/28
Engine: 305 NA 600 CFM holley.
Axle/Gears: 7 5/8 w/3.42 gears
1987 Z/28 305 C.I. T-5 Trans. 3:42 posi Diff.
Attached Thumbnails Road race thirdgen!! Pics wanted-21261419449_6061fdfb2c_b-2-.jpg   Road race thirdgen!! Pics wanted-20416007673_992b1c9974_b_55e8fd21ab733.jpg   Road race thirdgen!! Pics wanted-20414414564_ae7bff40dd_b_55e8fceea2841.jpg
Old Sep 30, 2016 | 04:35 PM
  #519
PurelyPMD's Avatar
Engine: LB9
When was that and what was the event?
Wish I had known!
Old Oct 19, 2016 | 10:43 AM
  #520
Passmenow's Avatar
Engine: V8
Old Feb 20, 2017 | 09:19 PM
  #521
Guycamaro's Avatar
Car: 87 Trans Am GTA
Engine: 350 Chevy
Transmission: Super T-10
This is the car we are currently running.
[IMG]https://cimg8.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x133
3/80-_j6a1244_079dcd0c4b4bb0e275f18d114b9082ca6dc5a2b9.jpg[/IMG]
Engine bay crossbraced
Early in the build
Old Feb 21, 2017 | 02:42 PM
  #522
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: This is the car we are currently running.
Those wheels look familiar...
Early in the build
Old Feb 22, 2017 | 10:56 AM
  #523
83RDRACR's Avatar
Very cool!!! Any specs on engine,drivetrain? Are those ZR1 vette wheels and what size f/r.
love the x brace tieing the front together. How about an interior view. Again great looking car
Dave
Old Feb 22, 2017 | 11:27 PM
  #524
Guycamaro's Avatar
Engine: 350 Chevy
Interior view
Bottom of the car from the rear.
Old Feb 23, 2017 | 12:27 PM
  #525
detltu's Avatar
Car: 92 Camaro Z28 1LE- Z03
Transmission: 5spd
That is one of the coolest 3rd gens I have ever seen. Congrats on a fantastic car.
Old May 20, 2017 | 11:45 PM
  #526
morrow's Avatar
Car: 92 Camaro Rs.R
Thank you very much soon to be an 311 destroked ls1
Old May 21, 2017 | 09:41 AM
  #527
rgauder's Avatar
Car: 1987 Trans Am
Interior view
Anymore build info on this car? How much did you move the engine rearward by? Looks like the firewall is still in the stock location.
Old May 21, 2017 | 12:43 PM
  #528
Guycamaro's Avatar
Engine: 350 Chevy
Not exactly sure how much we went back maybe 1 inch but the engine is also loerred about an inch too.
13.4 Corvette brakes up front
12.0 Wilwoods in the rear
800lbs and 200lbs springs
nascar style screw Jack's front and rear.
weight is about 2940 lbs full of fuel
Super T-10 4speed
3.00 final drive
275/40-17 Toyo R1Rs
Custom built LaJoie seat
Old May 21, 2017 | 12:48 PM
  #529
rgauder's Avatar
Car: 1987 Trans Am
Thanks, it's a nice looking car.
Old Jul 3, 2020 | 04:08 AM
  #530
McLovin1181's Avatar
More of an Autocross car but I'll contribute to an ancient thread.
Austin's Red Camaro was my inspiration for going racing in my 92.
I'll be ditching the 245 street tires for some 315s on all 4 corners spoon
Old Sep 18, 2020 | 02:48 AM
  #531
efs89's Avatar
Transmission: TKO 600
Keeping a dying thread going. OG 89 Players Car
Old Sep 18, 2020 | 12:38 PM
  #532
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I like it! is that a current picture?
Old Sep 18, 2020 | 01:16 PM
  #533
efs89's Avatar
Thanks. Yes it is. I'll be running and updating this car more as time allows.
Old Sep 18, 2020 | 01:39 PM
  #534
hotrodln's Avatar
Engine: Lt1 in IROC
I occaisionally run my 87 with 92 LT1.....engine needs a bigger oil cooler and the diff gets bloody hot too.....gotta do something with that
Old Sep 18, 2020 | 02:03 PM
  #535
efs89's Avatar
That's cool. This car raced through Canada and into NY as well. It's sporting a 350 TPI with a modern Holley HP computer and upgraded electronics and other things. I'm plotting suspension and other upgrades but struggling with departing from its original racing heritage
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
gta power
Aug 13, 2015 06:15 AM
Exxon Limited
Aug 9, 2015 08:13 PM
