Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Need to get ready for the strip!!!
Old Feb 15, 2009 | 11:49 PM
CrimsonBeast's Avatar
Car: 1989 Iroc Z
Engine: 350 v8
Transmission: 700r4 with transgo shift kit
Axle/Gears: stock. 3.23
I need to get my 1989 Iroc Z 350v8 ready for the Drag Strip on May 3rd. I want to install rear end gears and get slicks. I was thinking about maybe chipping the car, but im not sure.
Any ideas on some mods ( under $1k or $2k total ) i have a custom exhaust already, other than that it's stock.
Old Feb 16, 2009 | 12:08 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Need to get ready for the strip!!!
subframe connectors are a must. Based on your engine combo possible 3.73 gears or 3.42. Along with a higher stall torque converter. Port the heads, possibly a new cam. You could do quite a bit for under 2000
Old Feb 16, 2009 | 12:05 PM
86 IROC's Avatar
Stall converter and suspension mods. Leave the gears alone if it's TPI. Get everything you need to start doing your own chips. Make sure it has a recent tune up, and the fuel pump is healthy. You're on the right track buying a set of tires.
Old Feb 16, 2009 | 01:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
SFC and slicks then go racing.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
meeklay812
Oct 1, 2015 03:46 PM
TexasMaro
Sep 15, 2015 06:50 PM
Amillionoh7
Sep 5, 2015 11:44 PM
