well im going to the track tonight, there having an event called midnight madness and you can run from 9pm to 2am. its supposed to be one of the biggest street legal events i think theres one class that doesnt require license and inspection (plates)
last time out i ran a 11.81 on a 1.73 60ft with a 100shot spraying just out of the hole. i have since added a purge kit and im going to try launching with the 100 shot and see what that will do. then i plan on putting in the 150hp pills and see if she can run an 11.0
the car should have 10's in it but it needs more stall, im running a junk b&m 2400 and it will only footbrake to like 13-1400
A couple things - 1) the comonly no existent track prep at most "midnight madness" events, plus the moisture of being that late = poor traction. 2) If you have the tires/suspension to hook it the converter and car will work better if you flash it from idle or just off of idle, instead of loaded against it's brake stall point. Originally Posted by iroc.86
well im going to the track tonight, there having an event called midnight madness and you can run from 9pm to 2am. its supposed to be one of the biggest street legal events i think theres one class that doesnt require license and inspection (plates) last time out i ran a 11.81 on a 1.73 60ft with a 100shot spraying just out of the hole. i have since added a purge kit and im going to try launching with the 100 shot and see what that will do. then i plan on putting in the 150hp pills and see if she can run an 11.0
Too late now, but good luck - I guess I should now be saying how'd it do?
