Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
how do u launch?
Old May 6, 2009 | 03:52 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
how do u launch?
i have a 350 engine, 700r4 trans and stock rearend. whats the best and easiest way to launch? i usually launch in 2nd gear, but wanna get off the line or punch faster... any suggestions?
Old May 6, 2009 | 04:25 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: how do u launch?
engage the torque converter a little by giving it some gas then hold the car with your brake. then just put it to the floor and have fun.
are u running some sort of Drag Radial or slick?
Old May 6, 2009 | 04:36 PM
Engine: 355
no i got normal street tires. i gotta posi rearend and d.o.t drag tires im gna run. do i engaege the nos after i smash it to the floor on take off?
Old May 6, 2009 | 04:55 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
if your running anything more than 100 shot you wont hook off the line w/o slicks on N2O you can try but i doubt u will. are u running a window switch so the nos only turns on at full throttle?
i wouldnt hit the nos till 2nd gear just so u have time to react to the nos and will most likely hook.
watch ur rpms when hitting the nos it will go up FAST ecspecially if u spin.
Old May 6, 2009 | 06:12 PM
Engine: 355
im running a activation switch for full throttle. ya i kno the rpms sky rocket exscpecially in 3rd gear. what rpm levels too high to keep pushin the nitrous?
Old May 9, 2009 | 07:21 PM
Engine: 355
Old May 10, 2009 | 05:37 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
sorry. All depends on how your valve train is set up. anything under 5500 is good on stock valve train. Anything higher and your asking for problems. i would start out with lower shot of nos and work your way up. are you running carb/FI dry/wet?
Old May 10, 2009 | 06:52 PM
Engine: 355
im running carb setup. i dunno if im hitting the button to late or what. need more practice
Old May 28, 2009 | 10:57 AM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
Try launching in first gear. I have no knowledge of nitrous so I can't help you out there.
Old May 28, 2009 | 12:14 PM
Shagwell's Avatar
Car: projects.......
Unless he's got a manual vb, it is still launching in 1st gear no matter what position the shifter is in.
Every set-up is different. Try leaving just off idle and "flashing" the converter, and try leaving on the brakes against the converter. W/o some serious suspension and/or some good tires, you will have a tough time getting it to hook on the n2o in low gear.
Old May 28, 2009 | 05:25 PM
JesasaurusRex's Avatar
wheels up
Old Jul 11, 2009 | 08:54 PM
Engine: 355
id love to get the wheels up
darwinprice
17
Oct 11, 2015 11:51 PM
tuningnewb
Sep 23, 2015 07:06 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
beast94
Aug 20, 2015 06:44 AM
