Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
3.4 camaro goes 12.701@106
Old Oct 22, 2009 | 08:41 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
My first pass of the night was a 13.028@104.23. I was a little slow off the line 1.979 60ft (first time out since last year),then after waiting for hours due to clean ups I finally was able to make my second pass at 10:58 pm. I nailed a 1.856 60ft. with a 12.710@106.14. I'll be posting vids and timeslips soon.
Old Oct 22, 2009 | 10:13 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 3.4 camaro goes 12.701@106
.... very VERY nice times. I'd definitely like to see those videos.
Old Oct 23, 2009 | 05:37 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Here's the vid of the 12.701 run. My first run of the night was a 13.028@104
View Video on FQuick
Old Oct 23, 2009 | 06:53 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Congrats!!!
Old Oct 23, 2009 | 08:23 AM
Originally Posted by 3.4 grape
Here's the vid of the 12.701 run. My first run of the night was a 13.028@104....
Haha, that was you? I remember seeing that car over @ e-town. I initially thought that I was going to see a swapped 3.4 into a purple third gen, but either way, just like the video guy embellished at the end of the video; "yes, yessss". Nice runs. Should be headed back there tonight, will be looking out for you. By the way, what are your mods...?
Old Oct 23, 2009 | 11:56 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Nice? Turbo? When I was at the track there was a 3.4 4th gen with a 75 shot running 14.3's...
Old Oct 23, 2009 | 01:14 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Not bad for a 6 shooter! Congrats!
Old Oct 23, 2009 | 03:38 PM
project89's Avatar
congrats man u got my time by .290
looks like i finally have a reason to get my car back on the track, i set my time on the 3.1/ small turbo @ 9 psi and havent been back since i put the 60-1 turbo on
how much boost were u running
video of my old record run
http://www.youtube.com/watch?v=DQkHAUPXnLg
edit
now i need to update my sig
Old Oct 23, 2009 | 04:28 PM
^ FORMER 60* V6 FBODY RECORD HOLDER 13.008@104.65@9 psi....
Old Oct 23, 2009 | 04:32 PM
Stephen's Avatar
Car: 87 GTA
1/8? 1/4? Or the new "1/4 mile" 1000 foot track?
Old Oct 23, 2009 | 06:09 PM
It's definitely the 1/4 mile. If he trapped 106-mph in the 1/8th he'd be in single digit land.
Old Oct 24, 2009 | 10:03 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Nice my 3.4 camaro has a chance! Congrats!!
Old Oct 30, 2009 | 11:18 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Garrett turbo, intercooled, water injection, Delta cam, Crane 1.6 rollers, Custom intake, Smt6 controller, (4) 42lb aux. injectors, performabuilt level 1 a4 tranny, 3200 stall Edge converter, Alum. driveshaft, 3:42 gears and Nitto drag radials.
Old Oct 30, 2009 | 11:24 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
edit
Running 15lbs of boost. Yeah get that car fired back up! I promised the wife I would quit after getting in the 12's but it's so addicting.
Old Oct 30, 2009 | 11:25 AM
Nice! You should head over there later tonight, take advantage of the cold air. It's prolly going to be mobbed though, but with any luck, nobody will oil down the track and you'll get your full three passes. I'll be looking out for ya either way....
Old Oct 30, 2009 | 08:28 PM
project89's Avatar
57 trim t4 right???
i have some pics i gota get u so u can see some cyl head mods, if u can copy them from the pics u can get the boost level down into the 9psi range and still run as fast,
what cam u running btw? 260 grind ?
Old Oct 31, 2009 | 07:41 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
57 trim t4 right???
Would like to see those pics. I did my own porting and polishing job not too long ago. I'm running a 60 trim t4. Cam is a Delta custom grind.
Old Oct 31, 2009 | 01:35 PM
project89's Avatar
ok and dont have any really good pictures but this should be enough to get u on the right track,when i port another set of heads ill get better pictures
first up stock for comparison( intake port on the left the bowl has a lil work to it already in this pic)
now this pic shows the amount of material being removed from the valve guide and bowl areas, not real good pics for the ex side though( real ruff cutting to start)
guides should look like this once cleaned up and smoothed (this isnt a finished picture but close)
use a long tapered carbide for the ruff cutting, and a small taper carbide, and the ball carbide for finishing up the bowls/guide area. then after go with a 60/80 grit taper/stright paper roll to finish the surface
the port entrances u can take alot of the vanes on the floor but i need to get good pics of those.
i belive i have better pics and finished pics all around ill have to look for them
Old Oct 31, 2009 | 02:16 PM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Thanks for the pics. That's just about what mine look like except you took off a little more on the intake side. I like to leave a little more metal around the valve guides.
Old Oct 31, 2009 | 02:25 PM
project89's Avatar
yeah i took off a lot of material, but there is stil plenty around the guide, and it works well, what u cant se ein thos epics is how much i taperd the whole guide down were it goes back into the port runner.
the ex sides are cut back around the guides the same way i just cant find the pics of it right now
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
92projectcamaro
Aug 6, 2015 01:20 PM
