Clutch question
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Clutch question
Was wondering how long most of you give it before you start to "beat" on a new clutch. Such as hard launches and such that will put a lot of strain on it. I have a dual friction center force clutch. Also wondering what type of times people are running with these and if it will hold the power. Thanks for the info guys!
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Clutch question
easy for 500 miles, i'm pushing 380/420 to the wheels on a center force d/f
Re: Clutch question
You've launched it with slicks and no clutch slip also? Thanks for the reply
Re: Clutch question
Im using standard spec 3 clutch, gave it about 50 miles before I took it to track at the advise of other users who had trouble breaking theirs is.. I was getting tons of chatter prior, that first day smoothed it right out. Spec says that was the worst thing I could have done, though the clutch held strong for 3-4 years of serious drag abuse. Current clutch had about 150 mile on prior to track, launching at 6000 with 470 to the wheels. Will be spraying it soon on top of that.
Car: 1986 Camaro SC
Re: Clutch question
no i launched with drag radials, clutch never slips
rsrmoore
Aug 7, 2015 08:44 PM
