Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
How much weight can i save
Old Oct 2, 2010 | 11:48 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
by ditching the front and rear bumper, door bars(i am sure they are not that heavy) and the carpet and deadening material? I an trying to get my car on a diet and i want to know how much i might be losing, i think i can get into the high 7 pretty easily if i lose some weight that is really not needed, if i eliminate my wheel hop issues that is.
Any other weight loss suggestions are appreciated that are rather easy, i already lack a AC system and have a manual steering box.
Old Oct 3, 2010 | 07:23 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: How much weight can i save
Last year I took out the door bars and rear bumper support at the same time and threw them on the scale...40 lbs worth!
Never took the time to weight the front, but guessing close to 15 lbs.
The stock carpet with the sound deadening is a heavy mother! Remove that and put some of the lightweight stuff in, probably be good for at least 30 lbs.
Old Oct 3, 2010 | 08:15 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
If your looking for a lower weight just for the track, I would suggest skinnies up front. My stock wheel and tire for each side in the front weight somewhere between 30-40 lbs and my 3.5 inch skinny with a tire weight 7-8 lbs. Also you can take off your front sway bar, along with the wonder bar. You can get a fiberglass hood, drops around 35-40 lbs, aluminum driveshaft, aluminum heads. All of this could drop 150-200 lbs off your car and that should be around .2 seconds off your time.
Old Oct 3, 2010 | 11:54 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Already have a glass hood and factory LS aluminum heads, slicks and skinnies are on the to do list, just looking for the free weight reduction right now.
Old Oct 3, 2010 | 03:20 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Your car can't weigh very much right now. I would not remove the rear bumper or any interior. I doubt they would make a big enough difference, and make the car a little less of a street car. At 93 MPH you already have the ability to hit mid 7s in the 1/8.
Old Oct 3, 2010 | 07:29 PM
DIGGLER's Avatar
i still have my rear bumper support and door bars. lol thought about taking them out but never did.
Old Oct 3, 2010 | 08:20 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i figure removing the front and rear with the door bars and interior(and replace it with light weight stuff) would over all be a difference at the drag strip.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
92projectcamaro
Dec 8, 2015 12:25 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
