Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Stock IROC, first time at the track.
Old Oct 11, 2010 | 02:28 PM
85IROCzzz's Avatar
Car: 91 Z28
So I took my stock 305 IROC to the track for the first time yesterday. The ONLY thing it has that isn't stock is a TPIS big mouth manfold that the P.O. put on it but kept stock runners(stupid, I know.) Well I have to say, I'm slightly disappointed with what it ran.
Best run was a 15.77 with a 60' of 2.19. The 60' was pretty much the same every time, but the 1/4 time fluctuated from 16.0 - 15.77.
I thought It would do more like low 15's maybe even high 14's but I guess not. Now I'm gonna start the quest for better times. I already have headers and a y-pipe I haven't put in yet, and want to get some high flow runners for my high flow base. I was reading about all the "free mods" you can do and might try them but I'm not expecting 1/2 a second for gutting out the air box.
Here's a picture just cause:
Old Oct 11, 2010 | 02:47 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: Stock IROC, first time at the track.
Thats about online with what I've seen through SEVERAL 305 TPI cars, so don't feel bad.
Headers, y-pipe, k&N, bump the timing up to 10 * initial and you will gain quote a lot...
1/8th mile I started at 10.5's. With gears, stll converter, headers, camand ported stock stuff(SLP runners) I got it down to bottom 9's 1/8th or low 14's stock.
THEN I sprayed a 150 shot into the 12's!
Old Oct 12, 2010 | 05:48 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Sharp iroc!
What headers did you buy?
Expect to drop 2 or 3 tenths if you can still hook up the same.
Old Oct 12, 2010 | 06:28 PM
85IROCzzz's Avatar
Car: 91 Z28
Flowtech shorties, and also a flowtech muffler. Also, how much should cold air help? This time it was about 95 out, and next time should be some night passes at about 75 or less.
Old Oct 12, 2010 | 07:26 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Cold air will help a bunch, gotta have that engine BREATHE!
Take out the spare tire, and back seats next run, if you didn't already. (you can put them back in after racing)
The stock 2.73 gear, to a 3.xx gear would help a lot as well.
Old Oct 16, 2010 | 10:08 PM
85IROCzzz's Avatar
Car: 91 Z28
Service codes tell me it's a 3.42 gear so that's probably fine. As for the back seats, that seems like a lot of work for not that much weight reduction.
Old Oct 16, 2010 | 10:57 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Rear seats removal consists of 4 bolts, not hard to remove, but your right, not much weight savings there.
Old Oct 17, 2010 | 04:15 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Yeah, easy to take out and put back in, it isn't much, but it isn't much work for an extra few pounds.
Old Oct 18, 2010 | 09:55 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Have a timing light? Bump the timing... TRUST ME
Old Oct 23, 2010 | 02:09 AM
mikespeed's Avatar
Car: 87 IROC
Do you have any time slips still? If so would you mind posting them. I'd like to see the numbers. I also have a mostly stock 305. Mine only has the magnaflow 3" catback and k&n drop-ins
We have an 1/8 mile track near by and I think I was in the same ball park time wise on the 1/8 as Nuff last time I ran it. I'll be at a 1/4 mile track in the morning,.. not sure if it will be open to test and tune but maybe I'll see how slow I am there.
Old Oct 24, 2010 | 01:04 PM
85IROCzzz's Avatar
Car: 91 Z28
I can't scan them so I'll just post the numbers.
Best run:
REACTION: .0855
60 FT: 2.1995
330 FT: 6.4774
1/8 ET: 10.0645
1/8 MPH: 68.07
1000 ET: 13.0839
1000 MPH: 78.41
1/4 ET: 15.7788
1/4 MPH: 86.66
All of the other passes are pretty much exactly the same just a little slower from crappy RT's and 60ft's.
Oh yeah and I've never mentioned this baby is pushing 171,000 on the original motor.
Old Dec 14, 2010 | 10:26 AM
85IROCzzz's Avatar
Car: 91 Z28
Just took it again this weekend and picked up some time. All I did was take off that cat (which was only like 8 bolts) and it picked up more than half a second!
Weather was basically exactly the same as the day I took it in October(gotta love Arizona.)
Anyways I don't have the slips near me but I can remember some of the times:
60FT: 2.10 (previously 2.20 ish)
1/4 ET: 15.20 (Previously 15.77)
1/4 MPH: 89.something (previously 85-86)
I'm thinking 14.99 is easy with the headers I've got waiting and some cooler weather.
Old Dec 14, 2010 | 05:15 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
must be the sea level and air and temp where you live. mines a 87 305 tpi. i have headers, full 3" flomaster exaust delete pulleys and k&n drops runnin 15.5s at 86-87 mph
Old Dec 14, 2010 | 06:17 PM
85IROCzzz's Avatar
Car: 91 Z28
The track is at about 1190ft above sea level and it must have been at least 85 if not hotter this weekend when I was making passes. I do have the big mouth intake manifold but stock sized runners and throttle body so that might be giving me slight gains.
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 11, 2015 03:17 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
