? about gears
? about gears
quick ? about rear gears my car 87 gta is supposed to have 3.27 gear but i am going through the traps at 6200-6300 @ 120 car has 26 in tires th400 off the shelf 10in converter 3500-3800 is this right seems a little high to me thanks for the help
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: ? about gears
https://www.thirdgen.org/calculations
I'm guessing 3.90 or 4.11, assuming you were in 1:1 when you crossed.
Last edited by fireturd350; Aug 2, 2011 at 12:07 PM. Reason: 4.11 not 4.10 if it's a 9 bolt
Engine: 383 SBC
Re: ? about gears
Sounds right to me for ratios I mentioned. Only way to know for sure is pull the cover and read stamp on ring gear. You probably could use a fluid change anyways.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: ? about gears
Sounds almost identical to the first couple of years I was running my car with a 383. 3.27 gears and running 12.0 at 118 mph. Went to a 4.10 gear and dropped into the mid 11's, maybe just under 11.5. When I went to a 28" tall tire, I jumped to 4.56 gears.
I ditched the 9 bolt when I did the deeper gear swap. 10 bolt gears are much easier to find.
Car: 87 IROC L98
Re: ? about gears
11.0 with 3.27 gears is impressive. Just goes to show that you don't always need a deep gear to go fast but if you were geared for maximum 1/4 mile performance, the ET will get faster.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
