Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
afco spring question
Old Sep 24, 2011 | 06:03 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
OK, so the minitub is getting closer to being done, and I am planning on installing the afco 2 5/8" ID springs. My question is which one??? According to MOOG our cars factory have 107 in/lb rate, free length of like 15.5 and 10" installed.
I know there are several guys on here running these style springs, but, after searching I couldn't find where anyone said what length and spring rate they had.
Old Sep 24, 2011 | 09:14 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: afco spring question
I run the wolfe racecraft setup for mini tubs and their smaller diameter spring setup, specs are on their website. It's under 4th gen camaro, but same thing
Old Sep 24, 2011 | 09:25 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
So the 10" 150# si what your running then?
Old Sep 24, 2011 | 05:36 PM
xpndbl3's Avatar
Car: 1984 Z28
whatever they suggest on the site
Old Sep 25, 2011 | 10:07 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
150 is too much IMO, 120-130 will allow for some stored energy. You only need enough spring to hold the car up or you miss out on what your rear shocks are capable of...of course if your running monore matic`s on the rear then I guess 150 is just fine.
Old Sep 30, 2011 | 02:27 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Not much better a set of 3 way adjustables....
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
