Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Hooker Super Comps and evac tubes???
Old Jan 30, 2012 | 05:42 PM
Beeman's Avatar
Just trying a set of hooker Super Comps on for size. So far I've got the Pass. side in and the rear tube hits the lower control arm rear mount. I've modified the bracket a little to get clearance. Has anyone else had this problem? This is a SBC with a stock frame and Moroso solid mounts.
Next I'm looking at fitting an evac system in the collectors. With the rt. side in it's pretty tight near the starter, looks like the tube will be pretty short. Anyone done this? any pics possibly? I've got the 1/2 pipe and cutting it won't be a big deal, just wonder about the length. I'm guessing let about 1/2" stick down into the collector.
Old Jan 30, 2012 | 06:15 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
Re: Hooker Super Comps and evac tubes???
No idea on evac but I also had to clearance the stock K member, the passenger control arm rear mount.
Old Jan 30, 2012 | 08:12 PM
Beeman's Avatar
So far I just ground a little on it and it cleared. When I pull the engine I'm going to work on it a little more. Called Hooker and of course they've never heard of it. Driver's side went in like nothing. Didn't even have to lift the motor at all.
Old Jan 30, 2012 | 08:36 PM
DIGGLER's Avatar
edit- nvm, was gonna say look at your mounts but saw you had solids.
the evac tubes have a notch to tell you how far to insert them into the headers iirc.
Old Jan 30, 2012 | 10:45 PM
Beeman's Avatar
My evac tubes are 1/2" pipe nipples from the local hardware store.
Old Jan 31, 2012 | 05:38 PM
Car: 1987 firebird
Transmission: 4l60e
Notch them like the Moroso ones. I have always been told they pull better vacuum with the notch. Its a simple venturi set up.
I also run solid mounts. Im wondering if that slightly moves the engine allowing the passenger mount to hit? I ground mine flat on the one corner and then stuck a piece of metal up from the inside of the mount and welded it back solid.
Old Feb 22, 2012 | 02:40 PM
RaisinHale's Avatar
Car: 85 IROC-Z
Engine: 355 SBC
Transmission: Powerglide
Axle/Gears: Moser 35 spline w/ 4.56 gears
I have this setup on my car. It all fit but it is tight on the passenger side. I'll get you some pictures tonight.
Old Feb 23, 2012 | 05:10 PM
Beeman's Avatar
Here's pics of how it worked out. I notched the tubes for the venturi. Headers are now going to get coated.
Old Feb 26, 2012 | 03:32 PM
Car: 1987 firebird
Transmission: 4l60e
Very nice, keep us posted with your results.
Old Mar 18, 2012 | 08:49 AM
Beeman's Avatar
Here's the results after coating at M&R coatings in Kodak,TN
Old Mar 19, 2012 | 08:32 AM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
What did the coating run u for money?
Old Mar 20, 2012 | 05:56 PM
Beeman's Avatar
Mine were $220, I brought a couple of sets. It's more if you have any removeable pipes, less for street headers.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
75bike
Sep 20, 2015 09:37 PM
BLK87Z
Sep 18, 2015 11:29 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
