Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Finally got it to the strip
Old Sep 12, 2000 | 12:40 AM
IROC87350's Avatar
Well last saturday I finally took the car down and ran it after new engine/trans. After all the troubles I had getting it running and tunes I was finally happy with the damn thing. Here's what I have and what it ran.
88 iroc (original 350 car)
70's 350 4-bolt bored 30 over
Forged crank,rods,and pistons
Set of crappy 997 heads with 76cc chambers,160cc runners,fully freshened with 202 160 valves
Comp cam #12-238-2 (If I remember 480 lift 230 duration)
Accel high flow base
slp siamesed runners
everthing port and gasket matched
stock throttle body
needs a chip, will hardly idle with the set screw all the way out
edelbrock headers
flowmaster cat back
stock 277 gears
I tried to cool it the best I could, but it was always around 220 and it was about 85 degrees and humid. Out of five runs
Best 13.90 at 98mph with a .618 rt and 2.03 60ft
Worst 14.01 at 97mph with a .810 rt and
2.1 60ft
This suprised me because it has crappy heads
277 gears, and it needs a chip.
18 year old kid that needs to go faster
88 Iroc (still has a lot to be done)
93 4-wheel drive s-10
Old Sep 12, 2000 | 03:29 AM
Ski89Z28's Avatar
Hey, great times!
I have a 89 350 but my intake is still stock but I have a ZZ9 cam, level 5 chip from TPIS, edelbrock 6085 heads and headers and a 2000 stall converter.
And I only got one run in at the track. It was warm and humid around 80 degrees and humidity was close to 80%.
My time was 14.01 @ 97mph with a 1.248 RT!
My 60' was 2.05.
Once you get the custom chip you should be in the mid to low 13's if you still connect!
Myself I need a new intake manifold and I hope to be near mid 13's with the 2.77 gears.
Lots Of Luck!
89 IROC 350 Auto
TRUE DUAL Exhaust
Edelbrock Performer Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears
Old Sep 12, 2000 | 03:40 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Does it really matter what your reaction time is? I thought they subtract the reaction time from your overall time.
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter-the best mod so far
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph with traction problem. Have to try again sometime.
Old Sep 12, 2000 | 06:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, reaction time has no effect at all on your ET or MPH.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
