Stephen..converting to manual steering
Stephen,
I noticed on your website that you converted to manual steering using a manual box from a s10 pick up. I am removing the power steering from my camaro and was wondering if you just need the steering box itself or if I would need to take other parts from the s10 to do the conversion?
Any help would be appreciated
1991 305 TBI Paxton SN2000,Edelbrock intake and TES, Turbo city TBI,
MSD6a,Eibach drag lauch kit, Hotchkis RTAs and panhard rod, Richmond 3:73 gears and Auburn limited slip, best ET 13.40 @ 105.4 mph
I've done the swap myself, and I got mine from an S10 (I actually think he got his from an S15) and I also grabbed it with the pitman arm, but he kept the original one I believe...so no, it's a really simple swap
-'82 Z28 (350, carb'd, 4.10's, Super Comps, plenty of goodies)
-'91 S10 (nice daily driver)
AIM me at: Unitedhope
ICQ me at: 77979548
[This message has been edited by crazeinc (edited September 11, 2000).]
ICQ me at: 77979548
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can use the S10/S15's pitman arm but the angle is slighty different. I put the camaro's pitman arm on the manual box. There's nothing else you need. Remove everything to do with the power steering and bolt the manual box on. The steering shaft will bolt right up to it.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
Car: 87 IROC L98
For street use I have no idea. I wouldn't recommend it if you have wide 16" rims up front. The manual box has more mechanical advantage than a power box so it takes more turns stop to stop. I have no problems driving around in the pits. If you're not moving and have to turn the wheels you can't do it with one finger.
Since my camaro is on the street quite often, once the car is in motion, the wheel is relatively as easy to turn as with a power steering box...the only difficulty is just turning it with it stopped, but even then it's not that bad.
Forgot to add that I'm only running 215's on 15" wheels, so the less tire is also helping out with the turning
[This message has been edited by crazeinc (edited September 22, 2000).]
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
