Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Altitude conversion for 1/4 times
Old Oct 5, 2000 | 02:12 AM
IROCKZE's Avatar
Car: 85 Mercedes 500SEL
Engine: 5.0 DOHC
Hey all,
Who knows where I would find a conversion formula to correct times for altitude. Ran at 5,800ft. and I want to know the sea level equivilent.
85 IROC,tpi,t-tops,fully loaded,black with red l/s "camaro" interior,91 Bose system, Fastchip,TES,AFPR,K&Ns,92 police 700r4
"The devil drives a Camaro"
Old Oct 5, 2000 | 06:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
http://www.calgarydragracing.ab.ca/altitude.html
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 5, 2000 | 12:52 PM
IROCKZE's Avatar
Engine: 5.0 DOHC
Thanks Stephen! Just what I needed. Maybe we could add this chart to the Tech section?
Old Oct 13, 2000 | 05:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
5800'? That sounds like Bandimere!
If you can believe that table, the Camaro's best becomes a 15.5 @ 87.2 mph. And, the '57 runs a 14 flat @ 100 mph. Wow!
Barametric pressure and humidity also enter into the equation, which the table does not take into account (Stephen alludes to the barametric pressure in his density statement). My racing buddies' drag computers said the equilivent altitude was 8200 ft when the Camaro made its best run of 16.71 @ 81 mph.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 13, 2000 | 07:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re-adjusting for density altitude I can actually use that chart to dial in the car. I have another chart similar to that one at the track with a breakdown for every 50 feet in elevation. When conditions change I can get a close enough reading to what my next run should be. Trouble is I keep red-lighting and my dialin means nothing after that.
Old Oct 14, 2000 | 01:16 AM
IROCKZE's Avatar
Engine: 5.0 DOHC
hey there 57,
Yes it is Bandimere I speak of! And only 10 minutes away from Lakewood where my folks live. I was able to get in on the last 2 test and tune sessions of the season. Best time was 16.234 @86.33mph. (Temp F was 65, relative humidity was zero, and absolute baromter was 23.41) I used the chart to compute that to around 15.0 @ 93mph. I would like to adjust using density altitude but I don't the formula.
Old Oct 14, 2000 | 11:00 PM
five7kid's Avatar
Hey, IROCKZE, I live about 8 miles from Bandimere. Spent most of my Fridays there this summer.
The barometric pressure they give you on your time slip is notoriously inaccurate. I've seen the same number as thunderstorms roll in, while guys with their own weather stations watch it drop. Or, the track number stays the same from 4 p.m. to 11 p.m., even though racers' weather stations have been showing it going up. Bottom line: don't believe your time slip when it comes to barometric pressure at Bandimere.
I haven't been able to get to the fall racing. I hope to have the '57 back up and running for the spring. Perhaps we'll run into each other.
Yes, Rudolph can stick his ol' nose in at the worst times...
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
tmellott89
Aug 16, 2015 02:58 PM
stalkier
Aug 13, 2015 12:59 PM
