Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Going to the track next weekend, first time need a little help?
Old Oct 18, 2000 | 04:42 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Ok heading to Byron, IL. next weekend. Any thing I can do in the next two weeks to seed me up that are nice and easy? And has any one ever ran Byron, any thing I should know about it.
87 Z28 305 TPI, Auto, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Old Oct 18, 2000 | 05:56 PM
ede's Avatar
ede
moving to racing board ,you should get more help there.
-=ICON MOTORSPORTS=-
Old Oct 18, 2000 | 08:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Not sure about their track rules. Bring a helmet just in case. Leave everything you don't need at home. Go and have fun first. It takes a little time to understand what's happening. Follow the directions of the starter. After you stage and are waiting for the lights to come down, go when you see the last yellow light come on.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 20, 2000 | 01:13 PM
rich1034's Avatar
Main thing to remember:
RELAX AND HAVE FUN
You will have a better time if you don't worry about being the perfect racer. Just like was said before, follow the starter's instructions, and go on the last yellow, if you even see the green light, you left too late. Racing is a blast, if you let it.
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
