what is the biggest size rims and tire u can fit
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
15x10 with 5.5 backspace fits with no problems. I had 26x10.5x15 tires and now have 28x9x15 tires on them.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
You can fit a 17x11" rim with 6" backspacing in the rear and a 9.5" rim with 5" backspacing in front.
315/35/17's in back and 275/40/17's in the front.
You might be able to fit a 285 up front with minimum rubbing.
I'm almost certain a 335/35/17 will fit in back but it would need at least 6.5" backspacing on an 11" rim which no one makes, so spacers would have to be used.
They'd stick out over an inch past the wheel well also. It'd look like **** but handle and accelerate like crazy.
Here are some old pics. http://members.aol.com/ca1leb4c
toronto formula
Nov 10, 2015 06:17 AM
