1/8 mile to 1/4 mile conversion?
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Approximately 1.5 times your 1/8 mile time.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
http://www.geocities.com/MotorCity/Track/5604/
Miles
88 427 Camaro
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Multiply by 1.55 and add about a tenth is closer for my ET's. There is no real formula to convert it. There are too many variables in the last 1/8 mile to get an accurate conversion. Any formula available would only give a best guess conversion.
Three of my runs this year 1/8 and 1/4
7.601/11.894
7.710/11.954
7.604/11.857
Your 8.8 would probably be around 13.7's in the 1/4.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
7.601/11.894
7.710/11.954
7.604/11.857
Best 60 foot: 1.662
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I had a big interest in this too because I run at both a 1/8 mile and 1/4 mile dragstrips.
Being into math and other ugly things, I developed a formula that is very accurate for my '87 with mods. The 1.5 formula is not very good, but OK if thats all you got. My formula is:
1/4 mile ET = -0.3730 * (60' time) plus
1.3613 * (1/8 mile ET) plus 2.5747
I know its complicated, but it works great.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(48psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Car: 87 IROC L98
hmmmm. didn't work for my best time.
-0.373 * 1.667 = -0.621791
1.3613 * 7.604 = 10.351325
2.5747 = 2.5747
Total is 12.304 and I ran a 11.857. Multiplying the 7.604 1/8 mile time by 1.56 will give me 11.862. Much closer.
2.5747 = 2.5747
