Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
roll cage or SFCs?
Old Apr 10, 2001 | 01:38 AM
theformula's Avatar
roll cage or SFCs?
You need ROll cages when you're in the 11s right? Is 4 point good enough?
Anyway, would it give me enough structural rigidty? Or would I need to use both the roll cage and SFCs?
How much do 4 points weigh?
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger, Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Apr 10, 2001 | 07:11 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need a minimum of a 6 point bar if you are in the 11's. A roll bar is good to 10.0 unless the floor or firwall have been altered. Then the roll bar is good to 11.0. Quicker than that and you need a full roll cage.
My 6 point bar made from mild steel (NHRA legal) weighs 70 pounds.
SFC are a must reguardless of how fast you go. Even a roll bar in a 13 second car will improve ET and handling by eliminating body flex.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
FueledSoul
Sep 30, 2015 09:18 PM
FormulaEngland
Sep 30, 2015 01:50 PM
tmork454
Sep 29, 2015 06:33 PM
