Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Helmet
Old Apr 10, 2001 | 02:54 PM
Alan84TA's Avatar
Helmet
Where is a good place to get a Helmet. What is a good one and how much do they cost?
Old Apr 10, 2001 | 04:14 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
www.racerwholesale.com and www.jegs.com have G-Force 2000 spec helmets for $130, last time I saw. Those helmets should be good for 10 years.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 10, 2001 | 08:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any motorcycle shop will have a helmet that you can use. Make sure it has a Snell rating inside the helmet. M95 are still around but you should be able to pick up M2000 now also. You don't need an SA rating helmet unless your car is capable of running in the 9's.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Apr 12, 2001 | 06:26 AM
KeithO's Avatar
Just choose wisely. Earlier this year, I got the $130 M2000 helmut from racer wholesale. After some checking, I learned that this was not "legal" for my local road racing course (Nelson's Ledges). Since I plan to put my IROC on this race track over the summer, I returned the M2000 (Motorcycle - 2000) and got the SA2000 (Special Applications). SA2000 is approved for more event types than M2000.
Old Apr 16, 2001 | 08:49 PM
q1's Avatar
q1
i got a bieffe that is snell 95 certified for 75.00 from shade tree. 1-888-742-3387
Air_Adam
Oct 22, 2004 03:41 PM
Dewey316
Jul 23, 2003 09:26 AM
TomP
Aug 27, 2002 09:56 AM
