Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
60' time's
Old Apr 16, 2001 | 08:57 PM
q1's Avatar
q1
60' time's
what is the best way to improve my 60' time? i tried to run my stall up but over 1500 the car moves no matter how hard i hold the brake. my best has been 2.095.
1988 Firbird Formula 350
150hp NX kit, Air Foil
K&N, Jet Stage 2, 8mm wires, MSD 6AL, Trailing Arms, Panard Bar, 3" Ex. with cut out instead of cat. 5" tach.
e.t.= 14.33 no nos yet
mph= 96.6 no nos yet
Old Apr 16, 2001 | 10:45 PM
NJ SPEEDER's Avatar
short times are just a matter of getting a good hook. with the power you have you should be capable of cutting a low 1.9 at least. a good place to start is always a good set of tires and some good shocks. if you can do rear control arms and relocators that would help a lot too. an aftermarket torque arm would be the ultimate.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Apr 17, 2001 | 07:03 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
There are 2 things you need to really get a good 60-foot time: sticky tires and a higher-stall converter. You can get decent times with good street tires, as I got 1.9's with my nearly-bald 255/50ZR16 Comp T/A ZR's, but I also have a 2400 stall Precision Industries converter (rated at 2200, but my engine is a torque monster for a 305).
BTW, your car won't foot-stall over 1500 rpm since that's the stall speed of the stock converter. Even with a higher-stall converter, it's not necessary to bring the revs up very much as the converter does the job for you. I know guys with 2800-3600 stall converters (mostly P.I. Vigilantes) that just load up the drivetrain some at about 1000-1200 rpm, then let the converter take care of the rest. With a 2800 stall converter and Drag Radials, Trax was pulling low 1.7 60-foots in his 350 IROC.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 17, 2001 | 02:57 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
A good set of gears would help too (3.42's or 3.73's). I have a 2400 stall, LCA'S and a Panhard Rod, 3.73's, and a Drag Radials. Leave the line around 1500 got a best 60ft time of 1.89
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
[This message has been edited by Joseph Andres (edited April 17, 2001).]
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
