Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
First time at the track ?'s
Old May 29, 2001 | 05:49 PM
AlexJH's Avatar
Engine: 5.7L V8
http://www.missionraceway.com
I'm heading up to Mission Raceway on Friday for the Street Legal races, but they have a couple of rules that I'm wondering about (rules are at the link above).
It says that vehicles must be drained of antifreeze before racing.
1) Why must this be done?
2) Do they mean you can only run water in the rad or do you have to drain and refill at the track? The reason that I ask is I'm going to be driving there after work, so I'm not sure if I'll have enough time to cool down.
Other than that, I'm ready to go. It an 89 Formula 350 that I just bought 2 weeks ago. It's basically tuned up, but I want to get some times before I start doing any mods. It's already faster than my 87 Bird with the V6
Old May 29, 2001 | 07:00 PM
NJ SPEEDER's Avatar
that is actually in the nhra rule book. i really doubt they will check that, i know mine has never been checked.
the reason is that if you pop a coolant line water can be mopped off the track really easy, anti freeze on the other hand attaches itself to the rubber already on the track and makes a slippy gooey surface to play on.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old May 29, 2001 | 08:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mission doesn't allow antifreeze on the track. You "have" to drain it and fill your cooling system with water. It's a track rule. Why? Although I never got a real answer, there's a couple of reasons they could only allow water.
They don't want any antifreeze leaking into the water table. Although I've never been to mission yet I think they are too close to the river and need to control any run-off. They could have the track policy just so that if you break something and lose your coolent, it's only water and not slippery antifreeze being laid down on the track.
I wasn't aware that they enforced the rule for street cars either.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
