My first time at the track!! Results and q's within
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Car specs are in sig. This is what i ran..
Run #1
15.592 @ 87.38
60' 2.152
Run #2
15.559 @ 87.83
60' 2.180
Run #3
15.651 @ 87.63
60' 2.212
I got my R/T's down; i went from a .803 to a .595 i still need to do better though.
I just left it in "D" and brought the RPM's up to about 1000K. Are these any good for the car i have? It just ticked over 100k miles and burns a little oil on start up. Over all i am happy.. The starting line is a little nerve racking but its fun!!
My dad took his 01 Reagle GS (supercharged) His first run, he SMOKED 1st and 2nd!!! When he finally had a good run he ran .1 slower than my fastest time! That car is darn fast though!
[This message has been edited by Omega (edited July 16, 2001).]
Run #1
15.592 @ 87.38
60' 2.152
Run #2
15.559 @ 87.83
60' 2.180
Run #3
15.651 @ 87.63
60' 2.212
- 89 Formula 305 WS6
SFC's, LCA's, Air Foil
Spohn Panhard Bar
Flowmaster Cat Back, Tranny Cooler
A/F Ratio Meter (not a mod but it sure spurs interest)
Trans Temp Gauge
Most "Free" Mods
3:73, Zexel Torsion Posi - 90 Eagle Talon 2.0
(Winter Beater)
Mods? Um, no
Its for sale!!
Email me if you need a decent back up car
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Did you spin the tires when you were leaving the line? Your R/T doesn' make a difference as far as your ET is concerned.
Your 60ft of 2.1X is ok but I would think it should be better considering your suspension mods. I get consistant 2.0X with my stock suspension.
When I run mine I go from idle, anything higher RPM wise and I spin too much. If you can go from 1000 RPM and not spin, thne go higher in the RPM range.. keep going up a little each run until you start spinning the tires off the line. I also leave mine in Drive (third gear)
WHat was the temp like that day.. and do you know the elevation your track is at? The warmer the temp, the slower you go, same with elevation.. the higher you are, the slower you run.
It's a lot of fun going to the track.. I just started this year, so there are a lot of people here that know much more than I do about racing
Just keep at it.. is your car good and tuned up?
My first run ever was a 16.43 @ 82
my last run a week ago was 14.46 @ 93 with the car pretty much the same as I started, just a few of the cheap/free mods.
Just keep at it.. is your car good and tuned up? My first run ever was a 16.43 @ 82
Engine: LS1 / LS3
I spun a little off the line but nothing i am worried about. I don't start from idle because i have a slight hesitation that i can't get rid of. I have all new plugs, wires, and put a new cap and rotor in the day before. It was hot as hell out there that day.. the engine was running at 220 deg. I have no idea what the elevation is. I was lauching around 1K RPM, and the last run i launched around 1.5K... the last run i had a crappy 60' time though.
Does anyone know if these are good times for my car? Does it indicate a good running little 305?
[This message has been edited by Omega (edited July 17, 2001).]
Since you have and '89 305ci Formula with TPI induction you should be running in the 93-94MPH range. With a 2.15 60ft time you should be running 14.7-14.8 with those 3.73 gears and mods you have. So no those are NOT good times for your little 305 unless your running in the Rockies with 100 degrees heat.
[This message has been edited by Like a ROC 89 (edited July 17, 2001).]
Car: 87Z
Engine: ?
Transmission: A4
Look in sig.
2.00 60'
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials,170* Stat and TB bypass.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.6 @ 93
“Fallen But Not Forgotten”
2.00 60'
