Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
front end shake after launch
Old Apr 29, 2012 | 07:43 PM
68rsss's Avatar
First run today my car launched and when the tires came back down they started shaking uncontrollably. I had to let off just after the 60 because it was so bad. Last year was the first year with the car and its never done that once. I checked all the steering linkages and everything up front and its all fine. Has anyone had this problem with theirs and what did you do about it?
Old Apr 29, 2012 | 08:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: front end shake after launch
Get your steering geometry checked. You want as much caster as you can get to help keep the tires straight. It also sounds like you have bump steer. Every now and then I feel a shimmy when the front end comes down but never bad enough that I have to let off the throttle
I limit how much suspension travel I have with some cable limiters. I have a bump steer kit but I've never had it accurately checked. Another option is to install a steering stabilizer.
Old Apr 29, 2012 | 09:06 PM
68rsss's Avatar
Thanks for the advice. How much travel do you have in the front? The front of mine is really low and has a lot of travel
Old Apr 29, 2012 | 10:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I can't remember the exact measurement but the cables stop movement before the struts are fully extended. I still want enough extension so when the front end comes back down that the shocks start to slow the movement down and absorb the impact. I also play with shock settings. During T&T passes, I usually set them on full loose and the front end pops up very easily and I can carry the front wheels to the 60' mark. The spectators always like that. During competition, I stiffen up the extension to help keep the front end down.
Old Apr 29, 2012 | 10:17 PM
68rsss's Avatar
Think ill adjust the caster and put some cables on and t&t with different amounts of travel then
Old Apr 30, 2012 | 08:29 PM
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
Ed Quay has a steering damper kit that will stop that. I am assuming that you've swapped to either a Vega or S10 manual box? Either way the Quay kit will take care of that shimmy.
Old Apr 30, 2012 | 09:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You might want to check the adjustment on the steering box also. It may be sloppy.
Old May 12, 2012 | 03:21 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I had this problem and the ED Quay shock fixed it. I had 6 degrees + caster Tight new linkages and manual steering box 28 inch frt tires and lots of travel. it does work for a 50$ fix
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
bamaboy0323
Sep 3, 2015 06:07 AM
