IDEAS FOR DRAG ONLY 3RD GEN
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
Ok, heres the deal. I'm buying a stock 84 Z28 with an auto 305 ( completely stock).I wanted to make a complete drag-only car . So I was thinking of putting in a 350 (carbureted),5 speed manual tranny? , porting everything,posi & new gears , good exhaust and racing cams, and seriously considering a holley 420 supercharger. My questions are
1. what tranny would be able to handle the 350 with the supercharger?
2. What kind of posi should i buy and would 3.73 gears be good for racing?
4.. What exhaust set-up should i get?
5. What other things must i change just to be able to use the 350 w/supercharger?
for a drag only car a TH400 or strongly built TH350 or 700r4 will get the job done, also getting a 12 bolt or 9" will be needed or a built with the best of everything 7.5 should also work as your not going bigblock. no need for exhaust as its a drag only, just run a full lenth header, or if you MUST run an exhaust you can cut up the floor boards and run a full 3" duel system.
Engine: 350 CID
ok...i was also wondering about suspension and what wheels i should use and will there be any changes ill have to make to the fuel system if i hook up the supercharger besides moving the carburetors...and what are the advantages and disadvantages or using two carburetors?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Look at my car and what I've done to it. You'll probably have to change everything anyway in yours to make it a good drag car. Just start with a good base car with no rust.
Stay away from the T5 tranny for drag racing. It won't last. If you want a manual tranny, look at getting an old 4 speed modified to work. You won't need the OD in the T5 anyway.
Also stay away from the 700R4 tranny for drag racing. Again you don't need the OD and the gear ratio between first and second is too great a range. A TH400 is a tight fit but will work. The TH350 is a good choice. A drag racing Powerglide is your best choice.
Gear ratio in the diff will depend on too much to just guess on it. It depends on engine output, tranny choice and rear tire height.
Exhaust, what's that? 1 5/8" headers are minimum. 1 3/4" are prefered but expensive.
Most of the time a single carb is all you need. You can stick a 1250 Dominator on it if you really need that much CFM. Dual carbs are dificult to set up anyway.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Terrell351
Jun 13, 2021 01:13 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fast355
Dec 2, 2016 06:33 PM
